Wiring
kjg26
Are there any wiring kits, similar to a 4 pin trailer connector, that I can use for a six or seven pin connector? Or will I just need to run individual wires on my own? As of right now I will just have running lights reverse lights. Eventually trailer brakes and other powered objects on the trailer
jwilson2598
Ok, you're starting from scratch, what I would do I look into the wiring kits and then if you want 7 wire add a 7 wire with breakout box. On my recent upgrade, the trailer already had a full 4 wire kit installed, so I just cut off the 4 wire plug, moved the wires to the breakout box, and then I was ready to go with adding power and I'm ready for brakes if I want those too.
taunger
