I am considering selling mine if you have any interest, not sure what size you need exactly but here is a run down of what I have.
CDN101 (1997 model) heavily modified for rugged offroad adventures
NOTE: All rust repaired and primed with Zinc Monstaliner and then coated with Monstaliner 2 part epoxy bedliner.
Fabricated and welded extended tongue for Power box, water tank and propane tank.
In the thread below, you can see a lot of the refurbishment which included axle repairs, brakes, sway bar and more.
Sway bar added as well.
5 x 5 lug pattern
Spare tire carrier
Metal hinged lid w/ 250# lifts
New Lid Gasket May 2016
Heavy duty oversize steel fenders (holds 300# each) w/ mud flaps
Dual 12V battery's with 1500w inverter w/ NOCO dual battery Charger
25 gallon on board water with hand pump and 1/4 turn faucet / drain (has frame guard to protect from impact)
Fiamma 2M Awning
Eezi-Awn RTT 1400 series
Roof mounted small firewood rack
LED Illuminated interior and under tub with external illuminated Push buttons
much more as well...
I can supply more photos as I need to continue the build thread here:
http://www.expeditionportal.com/forum/threads/88708-Pepe-Our-Little-Mule?referrerid=17713
The build thread is from James Pierce who I bought my trailer from. Since then I have done a ton of mods, including the above items.
Mike
