XJ Shopping Tips?
NorthernTouch
I've yet to see a case of "hard to diagnose" death wobble that couldn't be attributed to tolerance stacking of worn front end components. Sometimes it is one component falling off and it's obvious, other times just about every joint in the steering needs to be changed due to play which would normally be acceptable on other vehicles with less extreme suspension geometry. In my personal experience (not necessarily the most common one) the only time it's hard to fix is when the customer tries to nickel and dime his way back onto the road rather than fixing the whole problem at once. I'd buy an xj in a heartbeat for what they are. In fact I plan to as soon as I find a good enough one for the right price.
Bdiddy11
Unless you want less power and less MPG, then regearing for 31s "is necessary". You can do it a bit cheaper than having a shop do it. Older JY Cherokees you can find a front D30 with 4.10 gears. Get a Ford 8.8 out of an Explorer (you also get rear discs) there is a pre-made kit for like $200ish that allows you to get the proper shock mounts etc.
If you care about gearing, there are numerous charts out you can compare as to which gearing would be best for you.
http://www.jeep4x4center.com/jeep-tires/tire-gear-ratio-chart.htm
tatuedrednek
Wanderer
I drove my 97 with stock gears and 31"s and it really was not that bad. You can really only feel it on hills. I switched back to 30's due to having to navigate 3000' hills every day.
I agree! Mine had 31" tires and 3.55 gears and did just fine. I did regear to 4.56 but only because I liked having the extra power, and better engine braking on steep descents.
briboki
I think one of the biggest benefits of the XJ is the large aftermarket support and used equipment selection. There are plenty of forums with regional classifieds specifically for XJ's. I paid $600 for a used high pinion dana 30 and 29 spline 8.25 rear axle with 4.10's installed. That's a pretty cheap regearing especially after selling my old axles to offset the cost of the new ones. I also picked up my sliders and gas tank skid used.
I think regearing is mandatory with anything larger than stock tires, but I also live at 5000 feet and 10 minutes from the Rocky Mountains. Anytime I have fun in the XJ it's at high altitude and in the hills. If I lived in an area with no hills (at sea level) I could see stock gears with 31's working. I drove a friend's XJ (same year as mine) with 33's and 3.55's..... it was depressing. Just my opinion.
My commute is 4 miles each way all city. It takes about 12 minutes. With 235/75/15 duratracs and stock gears (3.55) I averaged 12.4 mpg. Same tires and 4.10's I'm up to 13.5. Mixed driving I get 15-16 mpg with both sets of gears. Highway seems to be about 18 with both sets of gears. I have never seen 20 mpg with my XJ. Mine is a 99 with 115k. In the last 2 years I have replaced almost the entire ignition system (spark plugs + wires, distributor + cap, etc), o2 sensors, air filter and the entire cooling system. The jeep runs great and hauls butt. Plenty of power to pass on the highway w/ 4.10's and it screams up big hills. But unlike everyone else on the internet I've never seen 20 mpg and I've never been able to chirp my tires from a stop.
With my 2" OME lift I needed a SYE. I shimmed the rear axle, rebuilt the stock rear driveshaft, changed out motor / tranny mounts, pulled the front drive shaft to eliminate vibrations from the front, etc. It came down to either a Tcase drop or SYE. The SYE solved my vibrations from the small 2" lift. If you're going to lift it, I would budget for a SYE and then spend the money on something else if you don't need it.
With two adults and two black labs you may find the interior space of the XJ lacking. XJ's are great little machines. Simple with 4 doors and solid axles. Easy to modify and work on. Cheap aftermarket support. A little on the small side and not as smooth as IFS rigs on the street (I used to have a Tacoma). I believe they are great value in the $5k range.
TwoTrack
Buy Once, Cry Once
The current setup is a Ford Ranger with an extended cab which is small but works. The main problem I have is that the dogs have to jump into our seats then crawl to the back, in the process getting our seats nasty. I do fear that we won't have enough storage space but I think a roof rack will fix that. Currently ALL gear stays in the bed of the Ranger under a tonneau cover.
The more research and build threads I read I think that a 2" OME lift with 29's or 30's will be perfect. After hearing all the vibration issues, I will definitely plan on installing a SYE at the time of the lift. I have found a 99 XJ with stock 4.10s but it has high miles and needs some body work, I have a few to check out this weekend. I don't want to buy on impulse and want to get the best we can.
@briboki - Do you have a build thread or any pictures of your XJ?
IMO, with 31" regearing is not needed.. anything bigger? regear needed.
Rear main seal has been discussed so I'll pass.
Another to look at is the heater core. it goes pretty easily resulting in no heat..
Good alarm system/anti theft device is a must.. XJ's can be stolen within a minute..(mine was stolen in less than 1 minute)
