smokeysevin
Sequoia rear disc brake conversion v1
The time had come to ditch the 94 lt1 camaro calipers and "custom" cut k1500 rotors had run their course. The braking performance wasn't great. I had never gotten around to hooking up the parking brake, they squealed badly in the rain or in reverse and were generally not where they needed to be.
I had ordered a set of sequoia rear rotors and calipers a while back so I sketched out some brackets and had them cut out of 3/8" steel at send cut send. Since they were prototypes, I added a bunch of extra mount holes so I could play with the position. I got it (mostly) right the first time and mounted them up. I got lucky in that the wilwood parking brake calipers and the sequoia caliper mounts are essentially on the same place so the two calipers were able to bolt up to the same bracket without needing to mill or weld anything.
To clear the calipers, I had to redo my leaf spring mount. Those were fabbed at home out of 3/8" plate as well. I added some "wings" to the end so they wouldn't fold over and bolted them up.
As the sequoia rotors have a larger center register than the 12 bolt does, I had some hub centering rings made up but made them taller than standard so they would index on the wheel spacer/wheel.
The setup worked well but the cable routing was a little too close too the u bolts so I adjusted the brackets in cad and send cut send cut another set out.
Sean
Sean
