A couple other things I forgot to mention in my previous posts I thought I would share.
My first Jeep was a 2-door XJ Cherokee that transitioned through 3 different lifts and tire combos. I learned a lot from that Jeep, and I really grew to appreciate the coil front/leaf rear suspention setup. The flexy front and compliant, yet stabile rear allowed me to traverse up to 4.0 rated trails with little difficulty and still provided a comfortable ride as a daily driver. I knew I would be applying this to my next ride. For all the strengths of the XJ, the weak point is the body and lack of a frame. You can take a piece of metal and if you twist it enough, it WILL eventually break.
This brings me to my current YJ. After my XJ was stolen I used the insurance money to buy a sweet MJ Eliminator, and after that was stolen I bought the YJ. This jeep wont be daily driven and it will be kept in the garage, thank you very much!
I am trying to incorporate as many XJ components as possible in this build as they as plentiful and inexpensive. Things used so far are front suspention components, AW4 auto trans, 231 t-case with SYE, 2 front drive shafts have been relived of thier double cardan joints for custom shafts, and I will installing an XJ tilt steering colum as well.
Other interior accoutrements will be Renegade suspention seats, high backs in front and a bench in the rear for long range comfort, and storage cubbies built into the space that once was the front of the wheel wells. Communications will be addressed when I get toward the end, ham and CB will be a must, as well a DVD system for entertaining my daughter.
I am hunting for a deal on a 28 gallon gas tank right now, combind with a couple Jerry cans a 400 mile range should be doable on aspahlt, and 300 miles is definte on dirt assuming the worst possible milage.
I am looking long and hard right now at using some of the wasted space in the newly extended frame to locate a water tank. MMM lots of things to ponder!
