Finally got a 4Runner half way through the summer, found a good one, now I believe I have enough done to start a build thread! Its a little high mileage but nothing to bad for a yota. Here she is.
99 Toyota 4Runner
SR5
4x4
Auto transmission
6cyl
208xxx miles(when I got her) 216xxx present
Very soon after she got home, the running boards came off. Better already.
Next thing was tires, the stock size was tiny and I knew I wanted something more aggressive, but not too much, so I went with 31x10.5 BFG ATs, the tire of choice on the ExPo. Also at the time of these pictures I was experimenting with taking the fender flares off, they are currently back on.
Soon after I had painted to stock 15in Enkeis black, and mounted up some Hella 500s. The wheels where sanded, sprayed with etching primer, a couple of coats of black and couple coats of clear. The Hellas are wired to come on with my high beams. Some time in there a trailer hitch was installed also.
Within the past few days I have added a CB radio, its a Cobra Ultra III, the cheapest around, $35 from walmart, and as of right now I have a cheap magnetic base antenna until I can get a fixed mount 3 footer for my rear bumper. The CB is wired to my power outlet, and can be turned off as not to drain the battery when the truck isn't running, since I have wired to power outlets to always have power. Haven't had enough time to see if the CB works well, but as little as I will use it I think I'll be happy with it.
I have also done the rear dif breather mod, and as mentioned above wired the power outlets to always be on. I bought some OME 891s yesterday, so a lift is in the works. Along the way she has also had both lower ball joints replaced after one failed on me, and all new front brakes(rotors and pads).
Future plans
-Lift
-Sliders
-Roof rack
-Front bumper
-Better CB antenna
99 Toyota 4Runner
SR5
4x4
Auto transmission
6cyl
Future plans
-Lift
-Sliders
-Roof rack
-Front bumper
-Better CB antenna
