SOLD!!!! Fully kitted Chaser Trailer by Adventure Trailers - used once
Thresh
SOLD!!!!!This trailer has been fully refurbished by the amazing team at Adventure Trailers after a trip from Vladivostok to Magadan. It has not been used since. It is currently located in Rocky River, OH. Build price was $15,000. Asking $12,000. Please email me with questions. jthresher@automotive-events.com
The specs are as follows.
Chaser Trailer Chaser Trailer Kit Chassis,Trailing Arm Suspension Cargo Box with gas strut assisted lid, Drop Leg Jack, Rubber Matting, Cargo Tie Downs, 2" Rear Accessory Receiver. Standard
Powder Coat Color: White with Black Chassis & Fenders
Fox Coil Over suspension, rated for 500 lbs of payload.
Nose box Steel Powder Coated Nose Box
Fuel Can Set Two Fuel Cans & AT Holders for Trailer
Water Tank 19 Gallon roto-mold water tank with 1.25" opening, 1/2"
drain plug and pump
Partner Steel 2 Burner Stove with wind screens
Shelf-Chaser Utility shelf for Chaser (16.5" x 43" x .75"), shaped and
finished hardwood ply with locator pins.
12V Power Auxiliary 12V Power wiring w/ night light,
ARB Adventure light, 3 fused outlets, battery tray and hold
down
31D Valve Regulated AGM group 31 deep cycle battery 105
Amp
EEZI 1800 Eezi-Awn Series 3, 1800 Roof Top Tent 70" x 96
RACK BARS 3 Thule Rack Load Bars on Adjustable Track
Tent Fitment Mounting & fitting
Chaser Tail gate 16" x 32" with locking T-handle
latches.
MaxCoupler Multi Axis Coupler, 3500 lb, Class II
Engel 45 Engel MT-45 liter Fridge/Freezer
Transit Slide Lock for Engel MT35 & MT45 Fridges
3 BFG Mud Terrain T/As Tire Size: 265/75 R16
3 Suzuki Equator/Nissan Frontier RimsOffset: +30mm Backspacing: 5.70"
Bolt Pattern: 6-114
1 Wheel Adapter Wheel Adapter from 6 on 5.5 to 6 on 144.3
BK2-100 Bearings (L68149/L44649), seal (10-19), 1.719" I.D. &
pin kit.
Pivot Rod with two 1/2" washers and two 1/2 x 13 lock nuts
TAAS Bushing TAAS polyurethane bushing
15 misc 12mm lug nuts, 12 for trailer tires, 3 for spare 1.73
Electric Braked Axle Upgrade with 10" drums, includes
break-away kit
SwingAway Swing away tire carrier for Horizon & Chaser trailers.
Bolt pattern 6 on 114
A library of photos can be downloaded here...
https://www.yousendit.com/transfer.php?action=download&ufid=M3BueW45bThubVZqQThUQw
Thanks!
Jeff
Xrunner
Nice looking trailer! Here are a few of your images, sized and thread viewable...
mmcan
Can you tell me why you went w the Fox coilovers instead of the airbag GEN 3 system AT usually installs? Perhaps Mario can comment on how they compare in ride stability on and off road?
Thresh
Yes it was that trailer and has been completely refurbished by the great team at Adventure Trailers. The trailer was built in May, 2010.
adrenaline503
I'm very jealous, I wanted this badly, even has the right bolt pattern for my odd ball Nissan Xterra. I'm sure you'll enjoy it.
mmcan
I'll be converting this to accomadate my JK AEV Pintler wheels. Maybe you and I can work a deal for you to get the wheels and tires? I'm in dallas.
60Dan
Hey mmcan
I have some 10 inch 5 on 4.5 hubs that I took off my trailer to accommodate a 6 lug pattern that will fit a jeep wheel
Nothing wrong with them, PM me if interested
Thanks
mmcan
I think the JK wheels are 5 on 5. I'll verify this and let you know if your option will work.
thanks!
iStan814
