OME configuration question
upcountry
Switching to stainless braided regardless of lift will improve braking power and is a good cheap upgrade ragardless of the lift height. Over 3" and you need extended lines especially the rear. Its easy to do yourself just rent a brake pump to bleed them properly.
keezer37
Brake Pump
Hose on bleeder screw, a inch or two of fluid in the jug, pump the pedal, watch for cessation of bubbles.
upcountry
Was talking about using a brake pump to properly bleed brakes by myself with no help. Brake pumps offer a quick easy bleeding for a one man job without having to jump in and out of the vehicle. They are cheap to rent and save a lot of time. I used to use the bucket method and pump the pedal but once you use a brake pump you'll never go back.
wilson
trim packers
anyone have experience with these? My taco leans and it drives me crazy. i would like to remedy this when I install this lift.
can anyone tell me if one will be enough?
Are they stackable?
there a way to tell how many I would need prior to building the strut?
I'd like to avoid rebuilding the strut to insert another.
Plannerman
Wandering Explorer
So how much lift does a properly tuned OME set up provide for a second gen Taco? I see 2 1/2 inches listed above, the ARB website says 2 in., and I read some old ARB literature that says 2.85 in.
cruiseroutfit
Are they stackable?
Generally speaking, no trim spacer is needed for a side to side level stance. My recommendation is to install the suspension spec'd for your truck and needs and deal with any lean issues in 3-6 months after the suspension has settled in. Its an 1-1.5 hour job to add a spacer and in fact for 5mm spacer (nets ~1/4+ at the wheel) you could deal with a top out spacer that wouldn't require complete dis-assembly of the strut. That said I'd prefer the use of the OME intended 5mm spacer. Spacers should not be stacked but you can run a strut (preload) spacer in conjunction with a top-out spacer so long as you accommodate for the added down travel offered by use of the top out. 1st Gen Tacoma's are cheap and easy to install a diff drop kit thus I would recommend that particularly if using a top out spacer.
V45W_Proto2.5
