Look what I got!
RichardT
lol, we were on a tight time crunch, so by the time I realized that I should be taking pictures, the rear end was all done, and we were half way through with the front, I'll try to take some pics tomorrow of the finished product for you guys....sheesh!!
lol
Sent from my iPhone
RichardT
Oddly enough, the portion of this install that I thought would be the toughest (removing and installing the springs), was the easiest, and what I thought would be easiest(removing and installing the shocks), was the most difficult.
The previous owner had installed aftermarket (oem) shocks, and whoever did the job left the old actuators for the shocks on. I figured it wouldn't hurt anything to leave them there, as long as they weren't swinging around.
This is one of the front shocks, both front and rear needed a little persuading to get in on the bottom end, on the front I ended up having to jack up the lower control arm to get the holes to lone up in order to insert the bolt
This is the bottom of the rear shock, we had to bend the ears on the attachment point in order to get them to fit in, but they closed up nicely once we tightened up the bolt. We still had to use a wooden block and a hammer to get them to slide in, it was a very tight fit.
This is the the adjusting bolt for the torsion bars, I took Grasscats advice and turned them 10 times each, and it was about perfect, I measured later from the center of the hubs to the fender, and it was about 1/4 inch higher on the left side, I'm gonna try and get a more accurate measurement, maybe from the frame or something later to see if it really is that much, in case my fenders aren't perfectly lined up, and adjust it accordingly.
These 3 pics are driveway shots of the finished product, sorry, no action shots yet, I'll try and get out maybe this weekend to get something on a local trail
I also decided to do a power upgrade, I heard these things net you about 5hp and 10ft lbs of torque to the wheels, I'll have to let you know later on if I feel any increase :smiley_drive:
I guess it's time to change my signature, as my baby ain't stock no more ;)
RichardT
Let me help you guys out...
:ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero::ylsmoke::sombrero:
BTW I love that picher lol
RichardT
Tires yes, wheels no. I'm trying to do this all on a budget, so I'm thinking of going with 33x10.5 tires, that way I get a little more size, but can keep the stock rims.
That will be later this year though, probably around summer, and most definitely after my tax return comes ;)
Sent from my iPhone
red87
I wouldn't worry about 1/4" difference per side. I'd bet every corner has a slightly different ride height. Mine sure does but they're all within 1/4" or so. No problems so far :)
scrubber3
Not really here
That's exactly what I did. I painted the stock wheels black and stuck my 33 10.5s on. I love getting the most out of what I have. Not to mention that they are lightweight, fit perfect, are tough, and I don't have to shell out a bunch of money for 5 rims when I already have 5 perfectly fine rims.
RichardT
I went out yesterday and gave one of the sides one more crank and it was now within an 1/8, so I'm happy. But you're right, even 1/4 isn't a big deal, that's probably the difference you get from having a few less psi of air in one tire anyways :)
I agree 100%. I don't see the need to go out and buy 5 new rims, on top of new tires, especially when these will serve me just fine.
fatrat
SE Expedition Society
I get more complements on my painted stock wheels on the Monty then I did on my Volk Racings on my old car. LOL!
Silverwulf
+1 on painted stock rims. $14 in mat black wheel paint ans a little elbow grease and a little scuffing of clear coat ans a few hrs later I had a nice set of black wheels. I think the Montero alu. wheel actually looks pretty good and could pass as a aftermarket wheel IMHO :) I have a steady hand from spraypainting RC car bodies for years, I didn't even mask off the tires. I free handed it!
Before:
attachment.php
attachment.php
After:
attachment.php
attachment.php
attachment.php
RichardT
Before:
attachment.php
attachment.php
After:
attachment.php
attachment.php
attachment.php
Great...all I needed was another project....:drool: those wheels look awesome. After scrubbers comment I was thinking about it, but after those close-up shots...I'm sold, the only problem is mine are chrome....that's probably gonna be a bit more of a challenge I'm thinking....
4xCoffee
