Java's Trailer build
Pikeman
It doesnt rain in Seattle.....But I can't complain as you are making much faster progress than I am. Keep up the good work and the updates coming.
java
Trying to see to find wheels and tires. I have 265/70/17's from my truck, was planning on using them. But I can only seem to get 17x7 zero offset wheels, I have 6" between my hub face and the frame. The tire measures 10" do you guys think that 1" of clearance between the frame and tire is ok? That's about what the stockers are at.
ericvs
I would say that would not be a problem. I guess the only issue would be if you were to air down (do you even have to air down a trailer??). But 1" would still be ample clearance even if you did IMO.
Are you going to run the same rims as on your truck? That would look sweet!
java
Airing Down will really only bulge the bottom of the tire. I'd love to run the same rims as my truck but 1 they are hub centric and 2 I can't seem to find it anywhere for a decent price or just two for that matter. Will probably end up with a black soft 8 steely
java
Titanpat57
Coming along nicely Bud....love that front toolbox....keep up the good work.
Nice weather's right around the corner!
Pat
java
Pat
Not around here! I have a couple months before the weather gets "nice" . Have to spray the bed liner outside, I was told absolutely not in my dads shop, and he has the compressor that is big enough. So it has to be in the parking lot.
DFWSFO
