Good-Bye Jeep Hello Ram
fasteddy47
Congratulations on your new ride Eddy! I like your model Dodge :Wow1:better than any of the newer ones. I look forward to see how your build goes. If you make your new Dodge anything like your Jeep, it will certainly be a sweet ride!:)
Thanks for the Kudo's Chilliwak..... Was just out in your neck of the woods last week. :)
Started on the lift today, new axle U joints, Hub Bearings, Axle Seals, rear Diff Bearings, Yada Yada..... Will be finished lift tomorrow than
will upload some pics.
Cheers
Eddy
fasteddy47
So this was a busy weekend/ 5" of lift/ New axle U joints/ New Front Hubs/ Inner and Outer Axle Seals/
Heres a few lift pics
Bushwacker flares are fairly simple to install..... I had them color matched by paint code a week or so back.... they look a little
brighter than the rest of the truck.... I guess I will try and bleach the paint out and get it a little brighter on the body :)
Also had a Linex Spray in done..I love the way it looks when its fresh .... Had them go deep over the
top rail as I have future plans for my roof rack and canopy rack.....
I wanted something a little different in the tire and wheel department. I have had SOOOOOO many sets of BFG Mud Terrains.....
I read an Australian Mag called 4WheelDriveAction.... they run super comprehensive tests on products..... The Cooper Muds came out WAYYY on top....plus
they are supposed to be fairly quiet!! I was super impressed on the noise level on the maiden voyage today. They are about as noisy as a BFG All Terrain!!! Lets see
how they work and wear :) These are 315/75/16's 35" Tall
Bought some Cragar Soft 8's off of Summitt..... Factory Dodge Center Caps fit.... I think they look pretty good!!
fasteddy47
Like what I see, nice truck and sweet mods, keep the pics and info coming, I'll stay tuned in!
Thanks Black..... I will keep the mods coming.... Next up is guage package to manually monitor engine, batteries, trans, ..... after that will be
charging system and multiple Optimas.
Cheers
Eddy
fasteddy47
A few days off this weekend....had some "Truck" time...
Mopar (Autometer) Guages and a pillar Pod...
Water Temp / Volt/ Trans Temp....
I am going to install a mechanical oil pressure guage when I install the new 5.9!!!
Also been working on some custom "Rocker Rails and steps...Should be finished those next weekend.
Wife hates trying to get in and out now :coffeedrink:
fasteddy47
Nice truck. I got rid of two of my Jeeps for my Ram.
I look at pic's of my Jeep...and go into a melancholy state of mind :confused: Glad I made the switch,,,,but lot's of bugs to iron out before
I can make it my own. The truck is just another Ram with a lift and Big Tires.... I plan to change all that by making it my signature Truck.
Sorting out all the driveline right now.... then onto the exterior.....ie Canopy, Racks, Lighting etc,
Cheers
Eddy
fasteddy47
Built some Heavy Duty Side Step... Rock Guards in the last few weekends.
2x4 x .125 wall / Frame Mounted with grade 8 RivNuts and Bolts... Powder coated them
light gray to match the upcoming bumpers, roof rack and misc..... Added a powder coated checker plate
skin on the top for traction... mounted those with stainless button head torx screws....
