I TESTED OUT THE FIRST DESIGN FOR THE LAND CRUISER LAST SEASON AND HAVE BEEN REBUILDING IT THIS WINTER WITH ALL MY NEW IDEAS.  HERE IS THE THREAD COPIED FOR MY NEW BUILD.  THIS ONE IS NOT DONE YET.  MY WATER TANK SHOULD ARRIVE TODAY.
Worked some more on my 3rd cargo build, second one for the LC.
I had done some work before, laying out the drawers (using the old ones), fridge and water.
I got the sides of the compartments built and a top cut.  That was it for the first session.
Today I made great headway.
I got all the compartments made and cut out as much wood as I could.  I am going to fill in the spots with 1/2" poly insulation.
From top left, clockwise:, Water, storage, fridge, drawer, drawer
Here is the layout of pieces for the sleeping platform.  The pieces will be connected together with hinges and latches...
It will fold up and lock into this.  Notice Ruff-Ruff modeling is approximate location in the truck:
Folded up in the truck for dog/gear divider
Unfolded and locked into place as a sleeping platform
Storage behind the fridge, with access by folding the rear seat down.
That's two thermarests rolled together in the storage area, with plenty more room.  This will be for "permanent" storage.  Gear to sleep in the rig and change the families clothes, etc...
Here's a mock up of the second module that will be able to attach and detach, the one that goes over the fridge for storage above.
Here's the whole platform together:
A lot of design issues got solved today...it was a good day.  My water tank should arrive next week and I've already got the pump.  I need a little more wood and aluminum and some 200lb hinges for the fridge/table slide.  The dog/storage divider will also be adjustable.  When we have a really big trip or other reason that we need more storage, there will be another setting where Ruff-ruff has to give up some space.  The divider (while at camp) will be able to be detached, unfolded, laid down over the back seats and attached in place, voila! sleeping platform.  It's totally going to work.
There's a number of combinations of my family that will fit with the fridge in place.  I'm also planning on adding an outlet up front, and making it so I can put the fridge in the passenger front seat for the night, fill in the hole in the back, and have a FULL sleeping platform.  Even so, without moving the fridge, it will get used.
I can really see my vision coming to life in this build.  I bet this one will last a while before V4.0.
HERE IS THE PROGRESS THE NEXT WEEKEND:
I made some more progress today.  My water tank didn't arrive, but the 200 lb slides did.
I use full length drawer slides at the bottom of the two drawers (24") so the drawers are fully supported down the length
However, I didn't want the drawers to open that far.  I also wanted some stability at the top since they are 12" deep.  So I used one pair of 18" slide on one side of each drawer at the top.  This really took the wobble out of the drawers and limits their opening length.
Both drawers out.
Fridge slide pulled out.
Bar table.
The idea is that one person could be standing to the left of the "bar", with the drawers closed, and using the tailgate table to prep food.  At the same time someone could come up on the right side of the "bar" and access the fridge to make a drink or get food.
I am going to use a kitchen spray nozzle that will mount here
It will extend way out to the side so you can wash your head and body.
THIS IS WHERE IT IS TODAY 4/5/12.  I'M WORKING ON IT MORE THIS WEEKEND.  WILL GET THE WATER TANK IN AND THE TOP SECURED DOWN.  HOPE TO GET ALL THE DOORS WORKING AND THE LATCHES FOR THE DRAWERS/FRIDGE SLIDE.
