Land Cruiser Photos
sbly
Tango,
We use one of the 70 series cruisers when it's time to do a chicken shawarma run.
Take care brother and have fun at the ExPo.
sbly
stephen13
XDrive
The Roof Rack is set slightly back and therefore there is very little reflected light from the windscreen The bonnet does not reflect the light as the lights are high enough up and the aim of the light does not reflect off the bonnet at all.
The lights work extremely well, particularly when you require all the light you can get on an outback road.
mk216v
Der Chef der Fahrzeuge
Which brand/model are they?
stephen13
XDrive
The Roof Rack is a Front Runner Wind Cheetah from South Africa and the lights are Hella in two different sizes. If you look closely you can see that the outside two are slightly smaller than the inside four. Which also helps with reducing any glare/reflection
I am busy designing and fitting some brush guards at the moment which will run from the roof rack to the bull bar and deflect any unwanted branches etc up and away from the windscreen, lights and hopefully roof top tent
Will let you know how it works when I am finished
mk216v
Yes, I noticed the two different sizes. Which model Hella's are they? Halogen or HID?(I'm looking at converting Rallye 4000's to aftermarket HID, hence my question)
Limb risers will be cool.
stephen13
XDrive
They are normal halogens with upgraded bulbs 140W I think was what I put in The conversions for the HID did not fit in this size housing without the ballast being mounted somewhere else and I did not wish to do this
The HID conversions are good but with so many lights I did not need it and it would have been better from and economics point of view to then look at a light bar
Hope that this helps
1977 fj40
Hello, here are a few of my 77 FJ40.
