complete expedition bikes
compassroseo
Yes they do work fast, that's their job. The bikes are not 'off' bikes they are going to be built from the ground up using high quality parts.
Yes your right, it's near impossible to build one do it all bike. And like another member said everybody has their own idea of the perfect bike. The bikes are intended to be a good starter bikes for newer riders. They That's why they are a 250 size. We do and will encourage modification of the bikes. And anyone who assumes that all of our changes to the bike are based on a single forum, would be incorrect. Most of the research comes from rides we talk to in person or over the phone as well as actual product testing from several people.
Our design team is made up of 4 people. Me, my business partner and riding buddy, an engineer and mechanic, and an avid expedition rider/mechanic
The dikes are very close to the same size is a klx250 ttr250 or crf250. There is only 3 colors on the bike black, green and some blue. They have Compass Rose hand guards\blinkers, C.R. brake and clutch levers, Front mounted warn winch, C.R. Rear rack and aluminum water proof and insulated containers, single head light with 2 aux. lights mounted to frame just behind the full skid plate and rock guards, all of the bikes also come with an axe, a shovel (both with hickory handles) a fire extinguisher and special compartment for a tool bag or first aid kit. The power plant for the Compass Rose Adventure (CRA400) is a air cooled single cylinder 420cc 10hp diesel engine paired with a manual 5 speed transmission. It has a chain drive to the 18" rear wheel. The front wheel is a 21" both have disk brakes. the engine is electric start with a manual start back up. The CRA400 will also use a goal zero solar panel the can be used to power the battery and 12v outlet as well as a USB charging port.
we will only build 4 bikes, which will be finished in the next few months, to be tested extensively in California. Then sent out a across the country with riders to be put through hell. Testing will take almost a year. The bikes will be available late next year. The price is still subject to change, but still around 6,000$
Tell me what you think? And I will be happy to go e more details just ask. =)
seavoyage
Rally Replica MCF450-R.
How about a Dakar Rally replica: Odes MCF450-R AKA Asiawing LX450. USD$2300 for complete motorcycle on Alibaba. Chinese copy of a Honda CRF450X, all parts compatible. Or as raced in 2012 Dakar by # 94 Wei Guang Hui Bike: Jincheng JC 450 Y cloned (or rebadged?) Yamaha WRF450. Roketa imports these type motorcycles into North America.
Rally Kit from Mecasystems
Specifications
Engine type: 4 stroke 4 valve SOHC Liquid-cooled
Bore and stroke: 96mm x 62mm
Compression ratio: 12:0:1
Ignition: CDI with electronic advance and lighting coil
Starter: Electric / Kick
Transmission: five speed wide ratio
Final Drive: #520T 0ring-sealed chain: 13 tooth(front)48 tooth(rear)
Wheel Base: 1483mm
Trail: 110mm
Seat Height: 963mm
Ground clearance: 345mm
Fuel capacity: 7.2l
Tyres Front: 80/100-21
Tyres rear: 110/100-18
Front suspension: 41mm inverted cartridge fork with 16-position rebound and 16-position compression damping adjustment; 315mm travel
Rear suspension: single shock with adjustable spring preload, 17-position rebound damping adjustment, and compression damping adjustment separated into low-speed (13 positions) and high-speed (3.5 turns); 313mm travel
Front brakes: disc
Rear Brakes: disc
Dry weight: 105kg
More info
The Ode MCF450R is badged by Jawa in Europe as the 450KMX:
In Argentina the MCF450R is distributed by Backfire as the BXF450Z: and by Heikon as the TT450E
AsiaWing Tests:
Frank
After owning a KLR, nearly everything about the bike needs to be redesigned to be effective. Of course this is my opinion, many folks ride these bikes around the world in near stock form. I myself would find that totally insane.
-The engine is known for a few major downfalls. If it were an automobile, the bike would be considered a lemon.
-The electric system lacks power for additional electronics. Power a GPS and a heated fleece, you've damn near exceeded the capabilities of the allotted amps.
-The suspension is totally insufficient for anything more than a 180# rider. Forget about gear.
-While the brakes were upgraded for the 2008+ model, the still suck.
-The bike has no center stand
-Many claim that the hardware (the subframe bolts) are very soft
-The wire harness was recalled
...see where I am going with this?
That said, the bike is a GREAT platform to be built on.
Things mentioned in this thread about the bike you may build sounds very nice! A bike priced a little over the KLR price tag but not that of a 990/Tenere/BMW/Vstrom that is proven and has a bit of internet hype could be a gold mine.
Best of luck to you. I will be paying attention...
If this is your site, get it up and running! http://compassroseadventuregear.com/
RHINO
i dont think they're here anymore. prolly figured out they would be in the 6 digits for a ground up pre production bike and went off to design coffee cups instead.
lonestrom
I've tried to find them on the net,no such company!!.
I think they were THINKING about starting a company but never did ....
dhuss
