exposed propane tank...
MrCyrus16
I'm mounting a 11lb propane tank on my M-416 trailer, my question is this...I'm mounting the tank before the DS fender and I'm curious if I need to build a shield to protect it from road debris. The trailer is going to be on a long trip this year, mostly on the highway and fire roads.
Thoughts???
Hill Bill E.
Oath Keeper
Should be fine, as they are built well.
I have mine on the front of my M416.
You may get some tire spray, but I doubt you'll get any damage.
Just be sure that the connection part has a cover on it, so it doesn't get dirt/bugs in it.
Hill Bill E.
Oath Keeper
cnynrat
X2, just keep the plastic cover on the connection to keep dirt and grit out and you'll be fine.
Robert Bills
My propane tank is mounted on the tongue, thus less exposed to road debris than in front of a fender. Note that the tank is positioned so that the valve is protected.
DonBeasley
Mine is on both sides behind the fender. We just got back from OX12. 17 hours of highway time each way. Other than a little tire sling we had no damage. Agree, make sure the cap is on the tank connection.
Mark Harley
My tank is mounted on the front of the tub.
A little rooster spray, no other damage or chips.
jet noise
Alright, I'm not trying to jack the thread, but WHERE are you guys getting your tank mounts? I want to mount a couple of 11 lb'ers on mine but can't find a mount bracket!
kevint
I've been wondering a similar question. I use the 20 lb exchange cylinders on my trailer. They come with a peel off plastic cover over the tank connection. Is there anything I can screw on to keep dirt and dust from getting in there?
Robert Bills
The tank is perfect. Is is custom? If not, can you provide a link? Great rig.
My propane tank is a vintage Manchester 13 lb. (3 gal.) horizontal ASME tank that was often used in marine applications. Unlike current DOT propane cylinders, it does not have an OPD (overflow protection device) and Acme nut. Instead, it has the traditional check valve to prevent overflow and a POL connector. As such, it requires additional care to be sure the valve is closed (no automatic shutoff in the valve), however these valves were used for decades with very few incidents and are not inherently unsafe.
Manchester shows horizontal DOT cylinders and ASME tanks on its website, however they are pricey. Also, the shape has changed and look more like a vertical tank placed on its side (although configured specifically for horizontal use).
You can still find tanks like mine on the used market at old school trailer supply yards and marine surplus outfits. Might take awhile, but they do pop up from time to time.
Honu
lost on the mainland
I did have road debris rip a hole in one of my scepter gas tanks ? Not sure what it would have done to a propane or what it was ?
I say put some armor on things exposed to stuff flying off the rear wheels :)
Metternacht
How do you get it filled? I didn't think anyone would fill a non OPD equipped Tank. Especially in CA.
Thanks.
-M
