Interior cargo rack
Vinman
Thanks, I've looked through that thread numerous times and haven't really found something that works for me.
I ended up building a rack similar to the link I posted but much larger. Overall dimensions are about 53" wide x 39" long and 4" deep.
I have the basic frame made now and will try and get the mounting brackets sorted out this weekend. I'll post pics once it's completed and installed.
Vince
toyotech
i made one for my 4runner but i had a roll bar in the rear that its mounted too. cant post up pix if you like
Ray_G
Very tempted to try this inside my Disco in the area near the alpine windows. Thanks for posting, sorry for the hijack!
grimbo
Here's mine in the back of my GU
You know when you have no cash, need a temporary solution and then suddenly its three years later and you are still using it? well this is the case with these ideas.
I have never been a fan of drawer systems as I need the back of my patrol to be able to carry a variety of stuff and with kids and prams etc they take up too much space. I stated out 4wding in Suzuki Sierra ute so always managed to travel with a minimum of stuff and when my wife started coming along and we moved up into a Patrol that same mantra seemed to continue. So most of the stuff that I sued to pack in boxes remained in boxes.
The back of the patrol on camping trips now for myself, my wife and two young sons now involves a little bit more stuff. All the camping stuff ie tents, chairs tables, sleeping mats etc live in the small trailer (pseudo shed)
attachment.php
in the back of Patrol sits our Waeco 40L fridge on the left, next to that sits a large 40L plastic tub with all of the food. Ontop of this sits our clothes bags, then all the sleeping bags and pillows. Now this started getting messy and a pain to get anything. Luckily we already had a cargo barrier installed so I thought I'd love to get one of the purpose built ones as per this example
but they are hella expensive for what they are. I thought, while wandering through a hardware store, why not use one of the inexpensive clip and bracker style ones that you see in wardrobes. So $20 later, voila
works great, all the sleeping bags and pillows jam in the space and dont move at all, and no squeaks. Also is easy to take out if needed.
Then we needed a drop down table so found a daggy bit of plywood in the shed that happened to be the right size, sort of. Drilled a couple of hinges on, grabbed some bits of chain and there we go. Works great, cost next to nothing. Do need to swap the chains for cord though as they rattle. Then thought need somewhere to sort the odds and sods that you accumulate so grabbed a compartment bag from the hardware store for $10, attached with a couple of zip ties and now can store the bits and pieces and still use the table.
Then as the other door was now empty grabbed another bag and use it store a spray bottle of water, some hand disinfectant and a whole bunch of stubby holders and other bits and pieces
Now with the shelf in place the lighting situation was a bit dark so grabbed a cheapy fluoro tube light, some tool clips and a couple of screws and popped it in above the door latch on the roof. Best thing is I can just unclip it and have exterior lighting if I need as well. Just plug it into the power board at the back which is there for the fridge.
So there you go, my cheap *** temporary solutions that have been in place for a couple of years and will probably never get tidied up
I am here: http://tapatalk.com/map.php?3mfzm3
lupinsea
I made a cargo deck that converts into a camp table. Mine doesn't sit as high off the floor of the Jeep but it also slips into the front factory seat brackets and interfaces with some additional custom brackets that mount to the rear insta-trunk threaded holes in the back. Whole thing can be install or removed in about 60 seconds without any tools. And there is a matrix of threaded inserts all over the cargo deck so it's easy to screw in an eye bolt wherever you need an anchor point.
Cargo deck loaded up in the Jeep.
Image during the built where you can see the
threaded inserts. They are t-nuts that have
been glued in place with Gorilla Glue to make
sure they don't pop out.
The cargo deck - to - factory seat
bracket interface. It also acts as a
"hinge" so the deck and be pivoted
up for loading the bottom.
The rear bracket at support the deck.
These anchor in to where the insta-trunk
threaded inserts are.
The bottom side of the cargo deck with
the folding game table legs attached.
Cargo deck installed with stuff
stored underneath.
At the campsite the cargo deck converts into a camp table
by folding down the legs.
We just finished making another version of this for a friend of mine. His is much more built-in and has a semi-permanently mounted bulkhead that houses a subwoofer and two amps for his stereo. The bulkhead is integrated with two sidewalls that extend to the tailgate and "wings" that cover the wheel wells. The cargo deck / table portion sits on top of the bulkhead and flushes out with the top of the wings. Recessed into the top of the deck are some aircraft-type logistic track for cargo anchors. The deck can be removed and legs screwed into the bottom of it for a camp table. His is tall enough that he has a lot more storage under it than me, but it makes his rear area unable to mount a back seat, which isn't a concern to him.
robert
Whatever you go with make sure that everything is secured. Looking at that Xterra site it appears that some of their gear could easily come forward in the event of a panic/emergency stop or a rollover. A friend of mine uses a rack in the back of his Jeep that looks like a small cargo rack; it's mounted to the roll cage but 'm not sure where he got it. It's securely bolted on; he puts heavier gear below and he has a cargo net that goes over it to secure lighter gear/duffles. I can't remember the brand but I've seen them on Jeep sites.
toyotech
Would love to see pics of your setup, I may be attaching mine to the roll bar as well.
Thanks
Vince
sorry i took so long to get back. im not use to this forum lay out and im just now going back and sub to all my old stuff.
heres some pictures.
zhukoveli
