UJOR Build Thread
Wood Kutter
Now that puts things in perspective. The Jeep looks tiny in that pic. I'm used to towing things that make my van look small.
ujoint
Supporting Sponsor
New project arrived from FL today, 37's???? Yes. 8" lift, dual shocks, stage 2 front axle, this is gonna be a SICK ambulance! It already has an interior that will make most jealous. Let the fun begin.
Interior shots
Don't want to hijack Chris' thread as I will be making a thread for the ambo when it's all of the way done.. I'd rather work on it right now.. Sorry guys.. but to keep you guys interested and the wolves at bay here are some interior pics..
ujoint
Supporting Sponsor
New Sterling 10.5 install kit is ready to go! The kit now includes the spring perches, shock mounts, hard lines, soft lines with mounting tabs, and a fitting to adapt everything to the UJOR rear brake line. I'l also be including and e-brake cable bracket, but it's not pictured. Price is $239.00 for everything.
notmiller
Chris, How does the e-brake adapter work? I already cut off the stock bracket because it sat too far forward for my set-up. I'm curious if I can use what you've got.
ujoint
Supporting Sponsor
It's a small plate that the stock (truck) e-brake cables connect to. You run them thru the stock van bracket thats welded to the frame, then the ends go thru my bracket. A new "jumper" cable then gets attached to the factory van cable going to the cab. I'll have some more info next week, as well as pics.
ujoint
Supporting Sponsor
MegAmbo is moving nicely! Springs will be here Monday, and I hope to have it on the ground by the end of the day. Can't wait!!!
Frame is prepped and ready for the springs & axle.
V45W_Proto2.5
