Nissan Photos - post your's
Abitibi
Here is our 4WD Crewcab Nissan cabstar 3.0L TD (yet to be transformed into a light weight camper):
and here is my friend's cabstar :
Nice platform! Seems similar to a Fuso. Did your friend modified the suspension? That's pretty decent travel! Too bad I don't think we have those here in Canada...
stlu
Both cabstar trucks have the same suspension system. The second one has tougher shocks and the frame is a bit stiffer. It is reinforced with additional support pieces, that is the only difference. Mine crosses axles even a bit better. They are similar to the Mitsubishi Fuso but they are a bit smaller and lighter. They are designed to be 4.5 tons but these ones are homologated as light weight vehicle under 3.5 tons. A reasonable light weight camper (3.2m x 2m with a pop-up roof to fit in a container) can be easily mounted on a subframe. With the camper, it can still be under the 3.5 tons limit and this has many advantages here in Europe. The cab over system makes it a very good option as a light weight overland vehicle for families (the camper can be 1m longer than on a def 130 crew cab for instance, which is a reference here for families).
ravscin
Ravscin
Hello there from Poland
Hello everybody.
Nice to drop-in to this forum.
This is my first message so I just want to say hello to You and introduce my baby-car
NISSAN PATROL TD42T high-roof, manual G-box with mech winch front (PTO) and el winch rear.
This pics is from my trip to POLAND-RUSSIA-NORWAY expedition in 2010
If you like to see more I will set new tread for this.
Regards
Rafael
Roy
Awesome, that's the road trip I've always wanted to take! Are you writing a trip report?
I'm going to try to write up a report as soon as I get caught up with work.
I'd definitely recommend you take the trip if you get the chance. It was truly awesome.
BlackX
It's been a while since I've posted. Here are a couple pics from my recent trip down to San Francisquito in Baja.
V45W_Proto2.5
