What fluids are you using in your Monty?
enjoitheride
Hello all,
I posted this over on the wire as well, and I was just curious as to what brand of motor oil, and filter, and fluids everyone was using in their GEN1? I have the 2.6L and I am looking for a brand to use exclusively. I am doing a serious overhaul of my Raider, and just want to see what has worked, or not worked for people. I never really thought to much about oil until joining bobistheoilguy.com. But not to many people have Montero/Raiders on there.
Happy trails to all
Monterorider
Really anything from decent brand name would work if correct weight oil is used during appropriate service intervals. For piece of mind I use Mobil 1. It's overkill. But I like to change it myself, take a look around, etc
Inyo_man
Don't piss down my back and tell me it's raining.
I've been running the following in my Gen III for ten years:
Engine: Castrol GTX and Wix filter
Differentials: Amsoil 80W-90 Gear Lube
Transfer Case: Amsoil Severe Gear 75W-90
Transmission: MM ATF
enjoitheride
I do have Amsoil in the differentials, and Pennzoil Synchromesh in my manual trans. However, the Synchromesh is about to come out, and Redline MT90 is about to go in.
Inyo_man
Redline MT90 is a great product for the manuel box...I ran that for years in my Toyota and never had any issues.
Inyo_man
Has the Castrol kept your engine clean? The previous owner of mine ran Royal Purple. The thing is spotless inside..
I've never torn into the engine so I really can't say how clean the inside of the engine is...
From what one can see with a flash light down the oil port it is very clean. (Changing the oil on a regular basis is something I've always believed in.)
If the rig has a good record running Royal Purple, why are you looking at switching oils?
enjoitheride
Royal Purple is just really expensive! I am trying to find something that is just as good, but cheaper. I put Chevron Supreme 5w30 in for now, and it seems good. I want to stick with a synthetic though since the head was rebuilt. I am searching for oils people have used, and had good luck with...
enjoitheride
Royal Purple is API rated now. Their HPS stuff is not though. That is the Hi-Performance Street oil. It is loaded with ZDDP, and some other stuff.
off-roader
My understanding is their marketing says they exceed the specifications however there is no API logo on the bottles which indicate they're not API approved/certified. Do you have an API certification logo on your bottles or RP? They may have begun having their oils certified since I learned that.
Should look something like the below.
enjoitheride
When I checked last it had the Starburst on the front and all. I will double check. When I called them about a week ago, they stated, that it met the new criteria. The HPS version is the only one that does not still.
