Endless summer vehicle: bigger than VW, but stealthy?
rsbones
Cliff notes: I'm looking for a vehicle larger than vw vanagon; wider than sprinter; lower, faster and less thirsty than fuso/npr; stealthier than small rvs or truck with campers. Need at least 9'6" interior length, 6'2" height and probably 6'6" width?
Long version: I've always wanted to be one of those oldtimers who just hangout at the beach and surf all day, and I'm getting close to just doing it. I'm trying to find a vehicle I can build up and use over the next few years for extended surfing trips, that may turn in to a life on the road. I may spend some time in the mountains, but don't anticipate needing much in the way of off-road capabilities or cold weather capabilities for that matter. And I'm trying to find something that would blend-in in an urban environment so that I could stealth "camp" anywhere and avoid campgrounds and rv parks. I just can't find the perfect vehicle - little help?
VW Vanagon -- Very stealthy since many people still drive them as daily drivers and if poptop is switched to permanent hightop, can sleep secretly upstairs. But overall just too small for my surfboards and bike inside and rear engine location really limits interior layout options.
Sprinter -- leading candidate, but too narrow for me to sleep across the back and I'd like to do one of those permanent rear bed with "garage" underneath layouts. Is there anything wider out there? (i also just can't get used to the look of the sprinter van for some reason: too narrow for its height i think).
Truck with camper or small RV -- too obvious as a recreational vehicle to allow for stealth camping. Are there any that can blend in?
Fuso/NPR custom build -- love the design of the earthcruiser, but don't need anything that hardcore. I also don't need a truck with such heavyduty chasis: Is there a lighter weight version of this type of truck that will have better fuel economy, and higher freeway cruising speed capability, and allow a 6' interior height without being so tall?
What I really picture is something like the Mercedes T2 or Vario. The size is just about perfect and its squarish cargovan nature would allow it to blend in like a commercial vehicle. Unfortunately, not available in the USA... (unless I bring over a pre-'87 and feel like always ordering parts from overseas.)
Is there something I'm overlooking that would be a good platform for a custom build to suit my needs? Any ideas appreciated.
lqhikers
steathy ? open your eyes.
rsbones,
i do not know where you live in the bay area but i hope you are kidding when you can
not find a "steathy" rig.
very easy they are called box vans for one for another there is the lowly step van.
both types will suit your needs,both types come in many forms,gas,diesel,tall short,
wide you name it.
both will do everything you requested at any price point you choose.
Les,lqhikers
cwsqbm
The Nissan van isn't really wider than a Sprinter on the inside. The problem is that all the production vans struggle to stay under 80" wide, and therefore have interiors with less than 6' of width for sleeping because of their curving bodies. A typical flat-sided single rear axle box truck has a bit more than 6' interior width (about 6'3 for the one's I've seen), and would also give 10+' of interior length and plenty of headroom. The DRW box trucks are generally 96" wide on the outside, but you'd also have to deal with that width in parking or other places.
From ToyFamily's One Ton Man Fort build thread.
attachment.php
rsbones
Thanks guys. Box vans and step vans are indeed stealthy, but they are usually way too large (and thirsty...). If there are any smaller trucks/vans, smaller than the typical ups freightliner mt45 type or the 14' uhauls, I'd be interested in hearing about them though. Do you know any models?
The smallest uhauls are the ten footers with the gmc 3500 v8 and I think they are close to my desired dimensions so I'll go take a look. I'm not big on roll up rear door, but I suppose the box could be modified in many ways.
rsbones
-cwsqbm, thanks! I was typing while you posted. Maybe I've been too quick to overlook that type of truck. Thanks for the recommendation.
bahndo
Supporting Sponsor: Bahn Camper Works
You could get really crafty and cut the back end off a sprinter and add a box that is just a little wider with flat sides. Then you could maybe go with the low roof version and cut down on frontal area, although I'm not sure how much mpg benefit you gain by doing that. a quick google search should say.....mmm looks like driving under 65 gives the greatest return- oh well I guess I'll never experience the mpg potential of my vehicles ;).
-Bahndo
ihatemybike
Sound like what you need is really a Class C motorhome or ambulance conversion. I've been following a blog of a guy living full time in a Class C for the past three years. He hasn't had any trouble finding free places to park or been harassed.
http://www.tosimplify.net
Chuckles!
There are few Sprinter box trucks out there that would do what you want.
This one's box is 15' long, 5'10" high, and 6'7" wide. So a little squatty, but there are taller boxes out there on the backs of Sprinters with some searching. http://www.lonestarcars.com/vehicle/3948618/2007-dodge-sprinter-box-truck-plano-texas-75093
Also, there are some step vans out there with a Cummins 4BT diesel and manual transmission. These have great access to the back, stealthy, not too thirsty, and tons of interior space. Again, I've had a little difficulty finding one tall enough for my height, but they are out there and a great price.
http://cosprings.craigslist.org/cto/3096489544.html
rsbones
Thanks for the ideas. I think the sprinter has moved into the lead again, even the regular body. If too cramped by the width, those flares mentioned above would work out perfectly. Also it seems the current Fiat vans are being brought over by dodge in 2013 and the ducato is 6" wider than the sprinter so I may consider that. (I've owned 9 Fiats in my life but nothing newer than 1978!)
dwh
Tail-End Charlie
Just FYI:
Both of his trucks - the original Falcon, and the Chinook he has now - are Class B.
The Chinook Concourse resembles a Class C, but that doohickey over the cab is just a cabinet and not a bunk.
AeroNautiCal
The Ducato's are great for their interior space, nice to drive too, and reasonable MPG, though over here, we have what you may consider small engine sizes.
I'd thought of a small 'slide out' section that would accommodate a 'footbox' area of the bed, extended only for sleeping, and have since seen it done on small travel vans.
The Flare Space idea is neat, I've never seen anything (commercially available) like that before.
1leglance
One thing I have seen recently that I really like is a bed that drops down from the ceiling. That way you can leave it messy and just raise it up to gain your rear space access.
This might help with building a sleeping setup in a Sprinter that didn't need to be side to side.
Personally with your specs I would be all over either a Sprinter or a cheap box van (the money saved on the box van goes a long ways on the fuel budget).
DanoWall
