Self-recovery equipment for stock or close-to-stock vehicles
frgtwn
Bricks?
No, please, for your own safety, do not use bricks for raising a bottle jack, or any support under a vehicle. They will split, or break far too easily. Remember, a mason can break a brick to size with just a healthy tap from his brick trowel.
Disregard at you own peril.
Dale
FJR Colorado
Dale
Grey solid concrete bricks are pretty robust.
No, I would not use red clay bricks with 3x holes in them...
BurbanAZ
id try to avoid using bricks unless i had no other choice. Id always go for wood first, we use it all the time at work to crib cars when we are cutting someone out.
herm
any kind of brittle concrete or clay is a bad idea. solid or not. wood is much better and lighter.
Metcalf
At some point you just have to stop taking more gear in my opinion. Take a smart amount of gear, but don't go overload :)
A minimal kit and a good head on your shoulders will get you out of a LOT of bad spots.
-Tow strap, generally a long one that can be doubled over to make a short one to multiple attachment points. One time I had to use a long tow strap and a big stick to form a pulling device. I basically hooked the strap up to a tree and the vehicle. Took a big thick tree branch and made a lever with one end in a loop in the middle of the tow strap. Then you just twist the stick round and round causing the strap to get shorter. Amazingly it worked. I originally saw it in a movie when I was a kit....blue truck, water crossing, maybe in Australia? ( have never been able to find the movie ). You can also use a tow strap to tie a vehicle off in a scary predicament. Nothing like having your vehicle over the side of the road with 100+ feet still left to go to the bottom. In a pinch it can also be used as a tree strap, used to pull a rock or tree off the road, etc. Is it ideal for those uses...nope....will it work....yup.
-D-ring, preferably two. If you have to you can usually rig up an attachment point on one vehicle and not the other. I have seen a tow strap used with the strap fed back through the loop to form a noose at both ends. If you loop the noose over the tire you can sometimes get it very close to where the axle tube attaches to the springs. Not ideal AT ALL, but it can work in a pinch.
-Shovel. I don't generally care what kind. ANYTHING works better than having to take the license plate off and use that. There will be times that you just can't get the shovel under the vehicle like I mentioned before. Generally I like a full size shovel with a full length handle if you have the room, if not a D-handle shovel isn't bad. Spend some time with a file and your shovel. Coming from a 10 year background in Wildland fire....a sharp shovel is a happy shovel and operator. Careful when using a shovel under a vehicle. You can get it caught on brake lines, wires, fuel lines, etc. That sucks, ask me how I know.
-Axe. There is a whole thread on how much you don't need an axe, but when it comes down to it, an axe is a FANTASTIC tool. It's not so much about just chopping things in half, but also about what you can make with one if you have to. It also can function as a decent hammer if needed...not recommended however since it ovals the eye out.
-Bottle Jack. It is very handy if it starts really short and gets really tall. Some fords and land rovers had factory two stage bottle jacks. They are not that expensive anyways. I don't generally buy into the hi-lift jack thing. They work great sometimes but generally I can't justify the size and weight. Most new vehicles don't have very good attachment points for a high lift either. A jack also has a lot of alternative uses....you can use it as a press, to help remove tire beads, etc. Having some cribbing around can be a good thing, but I generally don't want to take up what cargo space I do have with wood. Get a better bottle jack and most times you don't need cribbing. If you happen to need some, it can be made with the axe :)
Those 5 things have probably gotten me out of more bad situations over the years than anything else. By all means if you have the means get a winch, any winch. It doesn't have to be the newest wiz bang fancy $5000 twin motor gigglepin wide drum model. I have a $175 used Belleview upright winch on my willys. FANTASTIC winch, especially at a price like that. Some other things I have found VERY handy over the years....
-Jack base. A piece of 3/4" plywood works great. I have always liked a round piece that fit in the spare tire and wheel. Get creative and see what you can come up with for an interesting space saving shape hidden in an different area.
-Bow saw. A saw is nice to have. It can be better in certain situations than an axe, but I will always pack an axe first. You can make a nice 24" blade, 8" dia cut, collapsible bow saw for about $10-15 with a trip to the hardware store. It breaks down and stores in the handles, about 1lb or less, easy to store.
-Tools. I think this is a separate category. Breaking down vs getting stuck. I have used a lot of tools to help with recovery though. Don't go overboard however. Your vehicle will be a lot happier without an extra 200lbs in tools constantly in the back. Build a decent kit that will fit in a soft tool bag, have it be able to be strapped down in its home, and don't use super high quality tools that you can't afford to loose or use to help weld an axle tube back together on the trail.
-air compressor. Airing down is probably the most beneficial thing you can do for vehicle performance. Most people don't air down enough because they are afraid they are going to loose a bead. An air compressor helps ease these fears a little bit. Learn how to air down properly and deal with odd tire issues like loosing a bead.
Get out, get stuck, get yourself out, repeat....
Bergum
Hilift and chain. This can move your car in any direction.
Axe. To make good platform for the hilift, can fill a hole under the tire that has sunken in. To remove the tree that has you pinned in.
Ham radio, for when everything else fails.
Good friends, to help you with the car, the bonfire, and the good conversations...
B4x4.no
robert
Lots of folks seem to prefer the floor-jack over a bottle jack since they are more stable. You see them in a decent number of desert trucks. I know I don't have room for one though.
I Leak Oil
I can't afford to give up the space or extra weight of a floor jack either. Plus, I've found a bottle jack to be far more useful and fits in much tighter spots.
If time is what you're looking to save a floor jack is certainly your friend.
Snarky
Hell Paso
My FJ was the MOST plastic cladded vehicle. That doesnt affect the hi-lifts use as a winch from factory recovery points.
My truck had OEM tube sliders, you can use a high lift with an adapter for these to lift up tires and slide traction material under them. I would get a set of sliders (you can see if your dealership can offer you some factory ones for your vehicle) and a hi-lift. Plus get the tube adapter and the equipment to use it as a winch. It's a multitool.
I did have my Hi-lift mounted to the factory roof rack for a while. Most vehicles have these.
Conversely you can carry a hundred pound winch on a receiver plater, and mount it to the rear when you go out. It'll pull you out of the obstacle not get you through. Less useful than a hi-lift for self recovery, 5 times more expensive. Probably 40 pounds heavier.
I have a Hi-Lift "lift mate" adapter that lets you jack up a vehicle by the wheels:
http://www.hi-lift.com/accessories/lift-mate.html
Haven't used it yet though. Looks like it should work fine.
These words are usually heard when said object fails to perform its function ;)
Try it out or don't bother to carry it. Not just wheel adapters but any recovery gear. A hi-lift/farm jack is a great multi purpose tool, but people should really take the time to learn how to use it. Same goes for winch, axe, shovel you name it. Tow straps are not designed for and should never be used as a tree strap. It would safer to take the cable/rope around the tree, and yes it will most likely damage the tree. After seeing a shackle, hook and wire go through the windshield and rear window of a truck because they decided to use the tow strap for a winch anchor I would never let someone do it without at least warning them and clearing the area.
Metcalf
While I agree that tow straps are not ideal to use for a tree strap, I don't generally see THAT big of a difference. A tow strap is going to be dynamic, but is rated for the full vehicle capacity if not more. Most tow straps are rated at 20-30K if not more.
How was the tow strap rigged that failed?
TwoTrack
Buy Once, Cry Once
I have Ford Ranger, stock bumpers with no sliders. I do have 2 factory tow hooks in the front and a L3 hitch in the back. I have used the hi-lift 4 times to winch myself out of situations I shouldn't of been in to begin with. It does take some time but when you're stuck you aren't going anywhere fast anyway.
I have a Hi-Lift "lift mate" adapter that lets you jack up a vehicle by the wheels. Haven't used it yet though. Looks like it should work fine.
I also have this and its incredible. I can use it on the two front tow hooks to lift the entire front, I can use it on my L3 hitch to lift the back and I can lift any tire. I've lifted the rear a few times to "repair" the tracks so I could drive out.
Even for a stock vehicle the Hi-Lift is a great tool IMO. It's my go to tool, right after my shovel.
TwoTrack
Buy Once, Cry Once
I agree with this 100%. You should learn how to use a recovery tool in a controlled environment before ever heading into the wilderness with it. Learning to use it on the trail is not the way to do it. It's far worse to severely hurt yourself in the middle of nowhere, than to have your rig stuck in the middle of nowhere.
zhukoveli
