For Sale: Solar Water Filter
pcut
Made by Partner out of Pocatello, ID. High capacity total filter. Great for large groups etc. We have used it for our Grand Canyon 20 day river trips. Takes the hassle out of filtering and allows everyone to drink all the water they need! Email or PM me and I'll shoot out pics.
pcut
Solar water filter
DSCN1171[1].jpgDSCN1170[1].jpgDSCN1172[1].jpgDSCN1177[1].jpgOops! Price is $700.00 obo. Retail is over $1200.00
teotwaki
Excelsior!
Neat assembly and cool deal! Just the pump and filters cost well over that
Found the specs:
This water purifier uses a 0.5 micron filter with a charcoal block to purify your drinking water. Tests show that all bacteria, virus and harmful chemicals are removed, when the purifier is used according to instructions. The internal battery charge is good for about 6 hours use. A solar panel is available to keep the battery charged.
The Aqua Partner is a self-contained water purification system capable of supplying from 75 to 100 gallons of potable water every day. Output will vary on conditions such as season, altitude, and time of day. Recharging the battery is as simple as placing the unit facing the sun. The Aqua Partner ca be equipped to run from any 12 volt source, enabling the system to continuously produce clean, safe drinking water at the rate of 1 gallon per minute.
Filters: Screen pre filter; 5 micron sediment filter; .05 micron activated carbon block filter. Filter configuration can be adapted to specific water conditions.
Electrical: 10 watt solar panel; 12 volt gel-cell battery; current - 3 amps.
Performance: 99.99% bacteria kill rate; run time 1.25 - 1 .50 hr / 8 hr. charge; continuous 1 gallon per minute output available from alternate power supply.
Total Capacity: 1 gallon per minute
pcut
Price reduction!! $500.00
Thanks for the bump teotwaki!! However, in reading the text, I realize that the model I'm selling doesn't have the UV filter. I'm dropping the price to $500.00.
Works great and we've used it on a number of 20 day Grand Canyon trips with no issues.
teotwaki
Excelsior!
I modified my previous post on the specs to remove the UV references. It is a good thing that you are far enough away that I am not tempted at all. This unit would be great for disaster/survival.
