Wanted: CDN M101 Lunette/Spring/Castle Nut assembly
VanIsle_Greg
I know this is a long shot, but does anyone have a Lunette Ring, Spring and Castle Nut they aren't using and want to sell? If you do, let me know and thanks!!
Greg
VanIsle_Greg
Ask and ye shapp receive.
Lets see the work.
Just got shipped out today...lol. I have a "plan" for it. I want to keep my stock landing leg/lunette combo but want to add length to it. The CDN M101 is WAY too short IMHO from axle centerline to lunette, backs up a little on the twitchy side. I am going to extend the draw bar yet keep it easily reversable to stock config. If it all works as planned, this should be pretty kool.
Once I have it in hand, I will post up some pics. Just need a coupler of some description now. Hmmm.....
VanIsle_Greg
Arrived yesterday.
Getting hacked up this weekend!!
:cool:
VanIsle_Greg
Cut the ring off last weekend... completely killed 2 cut off wheels, they were for mild steel and not cast iron, so yeah...
Used a flapper disk to "adjust" the edges and square them off to fit in the receiver tube. Worked awesome, locked it right in there snugly...no movement.
Tonight I went over to Mikes from Trekken Offroad to do some work and some planning. I drilled through the cast with a 1/2" bit on a dril press and a LOT of cutting lube. Holy crow that stuff is hard to drill and cut. I then bolted it in place with a sweet grade 8 bolt Mike had in the fasteners bin, and then he graciously welded it up. Cast was nice and hot, the welds bonded very well.
Should have the extended tongue on this weekend with a standard 2" ball hitch for now until I get my coupler. Added bonus, the tongue will have the ability to rotate in the housing just like the ring.
Timboruski
