Hey all,
Trying to wire up some new lights onto the trailer. These lights have two bulbs in each housing. Each bulb is fed with it's own live wire. I am trying to wire in a DPDT switch to allow the following two settings:
position 1 - one bulb on each light on
position 2 - both bulbs on each light on
here is my terrible diagram for what i am trying to do: the issue that i am facing is that i would think that when i select position 1, the current will flow back through the blue wires(used in position 2) and light up all the lights under the schematic that i have laid out. Anyone have any suggestions?
Could i reverse what I am doing and just switch ground instead of power? What is the negative behind that(possible short, etc?), will this lead to battery drain?
Thanks,
Sam
Thanks,
Sam
