Installing a Volvo Electric fan on a 3.5L Montero
GrassCat
I posted this on the wire so I thought I'd share it here also.
I have a 1998 Gen 2.5, but it should work on all the 3.5L Montero's.
I got a Volvo 945 wagon electric fan from Pick n Pull for $38. The nice thing about pulling this fan is it's held in place with three screws located at the top of the fan. They are the torx type screws, so be prepared.
It's a two speed fan, that is it has three wire coming off it. Red is high speed and green is the low speed. Black is the ground. I use my Delta Current Control (DCC) model FK-35 35A Fan Control Kit to wire it up.
Here's some pictures
Stock radiator
The Volvo part is on the left
Volvo fan mounted on the radiator
Installed in the truck, looking from top side. Tight fit,but it's below the pulley by 1/2" or so.
looking up from below the truck
Works like a dream.
I forgot to mention that you need to trim the top of the fan shroud, remove the right angle part.
off-roader
OEM fan is driven off the engine and not electric. It's problematic when the going is slow off road since engine speed is also slow and this is why an electric can make a difference.
The Rover Shop
When you eliminate the fan you just remove the fan from the existing pulley which has the belt on it..The pulley remains, just the fan assembly is removed.. I believe the fan is on the water pump drive.???..
GrassCat
The water pump is driven by the timing belt. The fan is located on the cooling fan bracket assy which has the fan and a pulley that drives the alternator on the SOHC 12 valve engine and drives the alternator and power steering pump on the SOHC/DOHV 24 valve engines.
Houie
