80 Series Rear Upper Control Arm adjusters
Box Rocket
SOLDThese are very high quality custom upper control arm adjusters that are similar in design to the Slee adjusters but are more heavy duty. Installation is the same and will require welding. Cut your factory upper arms and weld these in for full adjustability to correct pinion angle and make propeller shaft angles correct again to reduce driveline vibrations.
These are in *NEW* condition. $180 + Shipping. Located near SLC, Utah.
The photos show two control arm adjusters as well as panhard bar adjusters. The Panhard bar adjusters are not available. The second photo show the control arm adjusters in the foreground of the image.
adventureduo
Dave Druck [KI6LBB]
Nice pieces. Good on you for putting the soda can in for reference... as they look tiny until you see that pic.
Box Rocket
They are anything but tiny. If anything you'll feel like the control arms themselves are the tiny peices. These adjusters are serious.
