Fenders for a JKU
McZippie
Walmart Adventure Camper
We have 2010 JKU Rubicon that isn't lifted and don't want to lift it. It has 33" tires that are also wider than stock. The tires rub both front and rear and because they stick out past OEM fenders, lots of mud is kicked-up onto body. Any recommendations for aftermarket fenders to address problems would be appreciated.
daveh
Mopar front mud flares will help immensely with the mud at least on the doors. AEV rears work well also.
Septu
With the tires out past the fenders, it won't make much of a difference. Looking at my JK and my buddies (I run spacers with stock tires, his is stock) the difference in mud along the side is amazing. His looks almost clean, while mine is filthy. When I had mudflaps on my old JK with 33 MTs the side was still filthy after a run.
There's a lot of options... however most are tube/metal ones. Not sure if that's what you're looking for or not. Check around on the various forums for JKs.
McZippie
Thanks all for the info... looked at the options, all the wider width fenders look kind of dorky... Bling factor is important (smiley face winky eye crap)
Rancho
Here is a shot of the Bushwacker flat fenders.
I know you said JKU but here is a JK with Poison Spyder metal flares.
project13support
