FRONTRUNNER UPRIGHT FLAT PLASTIC WATER TANK Austin Texas
TexasTJ
Climbing Nerd
I need to feel this tank. its never been used or installed into a truck. I want $200 firm there 275 from FR. I would prefer not to ship it, but will at buyers expense. Paypal or Cash.
FRONTRUNNER UPRIGHT FLAT PLASTIC WATER TANK (13.2 GALLONS)
50L up right water tank (13.2 gallons)
Made from food grade polyethylene and is BPA free.
Filler at top, hose at bottom.
Has cut outs to fit over wheel arches
Designed to fit behind back seat of most 4x4s and beds of pick up trucks
Supplied with hose but not with mounting straps. The are many different mounting possibilities and the tank is designed with 5 pass through holes for plates or straps.
SIZE:53.15”L x 3.15” W x 24”H
OTHER DETAILS
This tank ships with a Raco quick connect universal adapter on the end of the 12mm hose. Most quick connect adapters (brands like Orbit, Melnor, Gardena, Gilmour, Claber) found at any hardware store will work. Attach any standard garden hose fittings, and/or a shut off valve, etc.
The universal quick connect adapter can be removed to install a classic garden hose fitting at the end of the supplied hose. Look for a male garden hose thread with a 5/8” flare fitting. We suggest a product like the Gilmore 5/8” Male Mender.
YotaPilot
If sale doesn't work out I'm interested. Can you tell me what the width is on the bottom (space between the wheel well cutouts)? Where in Texas are you?
Thanks
TreeTopFlyer
Delivered. Water heater comes in this afternoon. Onboard water by this weekend hopefully. Will post a write-up soon in the forum. Heater isn't coming until 18th, false alarm.
mrlisk
What water heater are you using? Interested in how you're putting together your setup.
Sent from outer space
DanoWall
