off-roader
Bouncy seat is a suspension seat base that uses an actual shock suspension in the base to help soak up bumps off road. They're especially nice because they can be dialed in from plush to rough. You simply turn a knob to a setting based on your weight. You can then 'fine tune it' depending on your comfort preference.Okay so my next question is what exactly is a "bouncy" seat, I mean I have watched off road shows and they put in a seat with webbing under the foam to make it float more when off road, or are they like seats in a semi, or are they made out of a bouncy house? lol
Alternatives are also available from several aftermarket vendors offering suspension seats (mounted to the stock base) like you describe with webbing that absorbs the shock instead of the seat base itself. I like the seat base instead because it's Mitsu OEM alternative and you have the nice looking OE seats that match the rest of the interior instead of typically black aftermarket seats.
