Overland Hadley
on a journey
x2, this is my favorite camper build on ExPo :bowdown:
Thank you Dave.
A bit of an improvement since we met in Death Valley a few years back.
	Hi Jim, I missed your PM while I was internetting on the road, but I did answer your question back on post 1069. Let me know if you have any more questions.
p.s. I would also add to the list that FWC has improved the eye bolt mounting, as there have been problems with the unbacked bolts pulling through.
Just read through your build thread to get caught up with the work on your camper. Looks like you have some good projects going.
Sorry I was not able to get those gas struts shipped out to you before I left, do you still want them?
	VERY IMPRESSIVE to say the least! :clapsmile
I'm especially blown away by how clean, organized, and roomy the interior turned out.
That being said, I'm sure that your "shipfitters disease" will lead you toward more improvements as you continue to put the TARDIS through it's tests.
	Nathanael
When you get a chance, can you post more details on the install of your Go Light? That's a great idea! Bet it's handy for finding a campsight at night!
The mounting plate has shims to raise it above the trim strip and the screws. This gives a nice space to run the wires. There is a hole drilled in the floor of the cabover to bring the wires inside the camper, the hole is located above the mounting plate. After the wires were run through it was filled with silicone to seal it.
I drilled a hole in the base of the light to run the wires out the side. I then covered the wires with a protective wrap, and siliconed the hole in the light.
On the inside the wires are run along the side of the cabover (inside a protective wrap before going inside the wall) to the electrical panel on the front wall of the camper. I did not have time to pop the top and take some photos of the wire run inside, but I will do that next time I am inside the camper.
Let me know if you have any other questions or thoughts.
p.s. I had the chance to test the light after fireworks on the 4th. It is beyond impressive. It is a tight spot focus of light, with a nice soft spread of flood light up close. In fact, I upset the neighbors half a block away by mistakenly shinning the light on their house, I was having too much fun with the remote control.
:elkgrin:
*Yes, I know I mounted the GoLight backwards. When I thought about how I would use the light it seemed it would be primarily to illuminate to the side of the vehicle. (I want to travel with the light facing backwards so I do not have to have a cover over the lens. This way I don't have to plan ahead to use the light.) Because of the 370 degrees of rotation, mounting the light backwards means that I can move the light to the drivers or passenger side without rotating around the front. However, this does mean that if I am using the light facing forward I will run into the end of the movement 10* off center. Not ideal, 540+* of rotation would be nice.
	Hmmm, I must have missed the earlier post. I thought I read through the whole thread...numerous times.
I'm thinking of calling my project "The Galileo., for two reasons, the first being right now the roof is still off.
