Overland Hadley
on a journey
Thanks for the detailed response! I have to agree, finding "how-to's" on propane plumbing on the 'net is nearly impossible. I know you've been asked for a ton of links, but I'm wondering what kind of fitting you used for your "thru-hull" fitting on the propane locker? Or did you come up with something else to get the hose out the locker? Also, where did you source all the on/offs, angles, etc used in the propane setup?
Thanks!
Here is what I found most helpful, Fireboy-Xintex's Instalation guide.
http://www.fireboy-xintex.com/manuals/Single%20Tank%20Illustrated%20Diagram.pdf
And here is their catalog of parts.
http://www.fireboy-xintex.com/propane_detectors.html#Adapters
Also look at Trident's website as I think they have a similar diagram and parts list.
The on/off valves I used are from the local hardware store.
Also check out SLO_F-250 build thread (Link) as he has done some propane plumbing work.
