Fzj80 Keyless entry
Flagster
I have a 95 LC that when I bought it 2 years ago had a crappy aftermarket alarm on it...
I would like to return the truck to original factory keyless entry...
Has anyone done this...I think I was able to find the Rs3000 computer below the dash so I believe I can purchase a keyless fob and program it after tearing out the non oem alarm...
Any advice would be appreciated...
Thanks
Matt
djsixbillion
I did exactly this with my current 80 - removed the crappy aftermarket alarm which had its own keyless entry system, then plugged in an RS3000 box from a donor 80. There are key fob programming instructions floating around on the web (check ih8mud), just takes a minute. FYI, the RS3000 box and associated factory wiring plug should be under the driver's seat, or at least it was on my 96. I would think 95 should be the same?
LandCruiserPhil
I am trying to translate that..."let us know how it works out" as in...good ***************** luck...I have already tried
or...good luck I am interested in how it works out...
Regardless I will let you know...:)
No not at all...I am interested in how it works out....the results will be good to know
zhukoveli
