Gen 2.5 fuse box diagram
markdam
could someone please take a pic of their fuse box so i can print it and keep it inside my fuse box? Mine has worn off with age and i cant find a pic of one anywhere.. also looking for a 1998 owners manual.......
markdam
true on both accounts but was hoping somone may find it easy to snap a pic and upload it and then the community can be richer............... :0
off-roader
FWIW, you can find 2 pdf files of the Mitsu Motors Factory Service Manual (FSM) on mitsubishilinks.com. It's a 2 volume set hence the 2 files. I know for a fact an illustration of the fuse cover with fuse locations is in my 96 FSM. I would think the same will also be true for the 98 FSM.
Sorry, I don't happen to have a 98 or I'd take a pic for you too.
markdam
thanks a ton!!!!!!!
markdam
yep thanks was trying to troubleshoot my horn.... turns out it was the horn switch in the steering wheel. had to dissassemble it and drill the riviets but took me about a 1/2 hr to do then i rebuilt it with foam battery insulaters (one sided sticky) and a piece of aluminum foil. Just gotta be careful cause its the SRS airbag assy. wish i would have taken pics ..... horn works fine now
