Anyone with sPOD Source & Contura Swith Panel setup? If so, a few questions
brasskey
I'm thinking of cleaning up my wiring and adding a sPOD Source to my truck. I have a Tahoe so their products are obviously not tailored to my vehicle. That being said, there's no reason I can't use the source and my own set of switches, correct? I am also thinking of modifying a cubby hole in my vehicle console to fit one of the switch panels. But, I don't know the dimensions of the panels. Can anyone with the sPOD switch panels let me know that the dimensions are (LxW)?
Lastly, do people that have the sPOD setup recommend it? Any other recommendations? Thanks.
Rando
If you are not going to use the sPOD switch panel, there is not really much reason to use the sPOD at all. Just purchase a relay/fuse panel (for about $250 less than sPOD) and hook up whatever switches you plan on using. Bussman makes a nice relay/fuse panel for about $30 and you can populate it with the relays and fuses of your choice for another $30:
http://www.nxtbook.com/nxtbooks/waytek/catalog225/#/133/OnePage
brasskey
Thank you for the link. That wil work perfectly.
zhukoveli
