Lucky 8’s Project P38
dcarr1971
I can vouch for the fact that Justin is in no way gentle when testing out new products. He drives that Rangie like it's a stolen Baja truck. :D...
X2. I've seen this beast in person. No part Justin puts on it is going to get through without a serious workout.
Fivespddisco
Supporting Sponsor
Project update
With the sliders installed we played around with them a bit. Heres a quick review.
For the most part the install went quite well for these 3 bolts
But this one below was a little bit of a challenge. You needed to be spot on when drilling the hole.
As you can see in this picture the top of the slider fits snugly against the sill. You get to mount directly to the frame and still use the sill for support.
Over all We think they fit the truck nicely.
Playing on a gravel pile
coming down the pipe soon will be diff guards. As you can see from this picture we are on thin ice.
And finally here's a quick video of us testing the sliders.
http://youtu.be/A-DekoZ2QUw
Fivespddisco
Supporting Sponsor
Project update
The new Terrafirma Disco2 fender flares came in and we did a quick mockup to see if they're going to work.
You can see from this picture we are getting a serious amount of rub.
Once the flares are installed I think we'll have plenty of room.
Unfortunately we're going to have to remove the sliders and trim them a bit, but I feel the benefits of having a 33 inch tire out ways this little bit of extra effort.
The back doesn't appear to be having as much interference as the front and will not require much trimming at all.
Next up flare install
Fivespddisco
Supporting Sponsor
im using TF023v in the front and TF027v in the rear.
I hope that helps but please keep in mind that the springs will not work with stock shocks
Fivespddisco
Supporting Sponsor
Project help please
When talking to people about this project everybody has a different opinion on what size lift we have.
Hopefully we can clear this up. If anybody has access to a P38 with stock suspension could you take some measurements for us?
I would love to know the measurements in standard mode from the center of the wheel to the bottom of the fender front and rear please.
This is what we currently have on our project.
The front
21.5 inches
The rear
22 inches.
Just for reference the 305/70/16 tires on the truck
32 3/4 inches
Thank you for your help
stonemm2
ok i just went out an took some mesurments on mine.. i got 19in in front an 20 in the rear .....it looks to me that the person that did the coil conversion put some kinda of aluminum spacer between the perch an spring .... but im like you i have know idea what is stock .... but regardless.. from what i see im only around 2 in from my goal of geting the 33s on there.... an i bleave my current springs are either bad or the wrong ones because it rides like a tank(stiff) on the road and it will hit the bump stops way do easy ..... i do know the driver side rear sags but now that ive seen your mesurments i wander if i would need to pull out the spacers to fit the TF springs.....by the way maybe someone and answere this question ... are the springs for the p38 coil conversion specifically for the p38 or are they some generic land rover spring that works .....
Fivespddisco
Supporting Sponsor
Thanks for posting
The springs are for Land Rovers in general.
PETER PETRAKIEV
Can ask take pictures the springs in front and at the rear.
This are rear progressive springs.
TF023V Medium load rear coil springs. This spring is suitable for the rear of a Defender 90, Discovery 1 and Range Rover Classic carrying up to +200kg of additional equipment and will provide around 2” of lift.
TF027V Heavy load rear coil springs are designed to provide 2” of lift on heavily laden vehicles for commercial and expedition use.
The TF027V fits the rear of Disco1, Disco2, Range Rover Classic, and Defender 90s carrying a constant load or additional equipment weighing more than + 300kg.
Is not too hard ride?
SteveMfr
Supporting Sponsor
Measured to the center of the wheel opening:
Standard height...790mm
Off Road.............830mm
Access...............730mm
Motorway*.........770mm
Extended*..........850mm
*can not be accessed manually
Fivespddisco
Supporting Sponsor
Steve
Can I get a picture of your truck? They make them very tall over there in France
Standard height...790mm = 31.1 inch WOW that is almost a foot taller them my lift!!!:eek:
zhukoveli
