HAM Operators- Post up here
1911
In the general case 1911 is correct in that most VHF and above signals go through the ionosphere and dont reflect back, but there is always EME (moon bounce) were you relect a signal off the moon and work station thousands of miles away. Take a lot more than a simple mobiel radio nad antenna, but can be done. A little cheaper route is by using tropospheric ducting. Ducting is where your signals can bounce off of weather patterns(high pressure systems.) Common right before or after a summer thunderstorm. I have worked TX from Ohio before. Can work into Canada pretty regularly.
Good points all, my answer was over-simplified. I thought about mentioning bouncing signals off of satellites also.
mgalvez
KK6BOF, just got my call sign. So now its time to start chatting on some nets. Can't wait to try this out somewhere remote.
crismateski
American Adventurist
May I suggest the Outdoor Adventures USA net on Thursday nights. Keller peak repeater. If you want more info you can check out OAUSA.net or send me a PM. I am right next door in San Antonio Heights
irish_11
Passed my Tech tonight. Just waiting for my FCC paperwork to go through.
I am hoping to take the General in a few weeks
Edit*
KG7APZ
Kirkland, Wa
2m/70cm(440)
Ft-7900r
Congrats on your ticket! Post your call sign when you get it. Good luck on your General; it's easier while all the Tech stuff is still in your head.
seanz0rz
KK6BQA
Yaesu FT-7800R
Inland Empire, CA
just got my call sign this morning! Now to figure out how to use my radio...
BlownZJ
Forum Name: BlownZJ
Call Sign: KC6URU-7 (APRS)
Radios: 857D, 8900, VX8R (yes, all in the Jeep :)
Freq: 7.2MHz/147.520 T100.0
Petersmithinak
