1979 Ford Creger 4x4 camper
sambot
This could make a great project for someone
$7200 I don't know the guy, but I want his rig.
http://denver.craigslist.org/rvs/3625667225.html
1980 Creger 4X4 RV
1979 Ford F350 four wheel drive class C RV
17,518 original miles
25,000 on rebuilt engine
400 V8
4 barrel
Automatic with cooler
Transfer case - 2h/4H/4L
Manual locking hubs
Pwr Steering
Pwr brakes
AC
Dually rear axle
2 Fuel tanks with locking caps front tank - 19 gal./rear 38 gal. (aftermarket)
Two batteries - 1 auto 1 marine
Locking hood
Electric trailer brake controller - Tekonsha
7 pin trailer harness
Solid state dual battery protector
Dana 60 front differential
Dana 60 rear differential
64 gallon fresh water cistern
3 burner stove with oven
Kitchen sink
Refrigerator - 12 volt DC/120 volt AC/ Propane
Propane heater
Rooftop AC with electric heater
Bathroom - shower/toilet/sink
Grey water tank
Waste tank
Dual propane tanks
Sleeps 3 comfortably
Exterior storage
Rooftop storage
CB (don't know if it works)
Rooftop TV antenna
120 volt AC hookup
About 1.5 years ago to date-
New front tires (rear tires have almost new amount of tread)
Radiator flushed
2 new batteries
New plugs, plug wires with rebuilt engine (20K) as well as coil and points/cap.
New brake master cylinder
Transmission serviced
Various battery cables and interconnects
Factory starter rebuilt (stronger than aftermarket)
Belts and radiator hoses
Ignition module
Holley finned, aluminum valve covers
Edelbrock intake manifold
Edelbrock 4 barrel carb (brand new) with new electric choke and air cleaner
Vehicle AC updated with new compliant fittings and recharge (clean bill of health from mechanic - blows cold)
All rubber fuel lines have been replaced
Electric fuel pump
Tank selector
Fuel filters
Rear brakes, drums, axle seals and parking brake cables
Front poly tank flushed - new sending unit, overflow line and filler hose
Rear tank new (oversized 39 gal) - new sending unit, overflow line and filler hose
Front end is aligned (taken to Merrill Axle & Wheel for alignment but it was in spec)
Fresh water pump screen
Numerous plumbing fittings and line upgraded to Pex and Sharkbite
Rooftop AC - pillow block and run/starter caps replaced
Mechanically very sound. Starts in cold weather, runs well. Transfer case has Four Wheel Low which was not standard but an option - pulls very well. All appliances work as they should. No leaks - in or out. At 30 years old it shows wear but we've always kept it clean and sanitized. Previous owner installed extra propane tanks (about double original capacity). Rooftop AC has optional electric heat (great way to save propane if you have access to an electrical hookup). Fresh water cistern is very clean and can be filled from more than one point (either side of RV). Multiple drain back points on plumbing system to allow for easy and thorough winterizing. Custom welded - extra front bumper with three receivers and spare tire mount. Locking external storage. RV body is not fiberglass but bonded aluminum (aluminum shell with injected insulation - nothing to rust or rot). Extensive paperwork from original purchase and some for aftermarket parts. Most all work done by a certified mechanic. Being on a truck platform vs a van makes engine work much easier on this RV. 1979 Ford F350 strong drivetrain - great sources for parts. Two sets of keys.
This will sell fast - a great getaway RV.
$7200 or best offer
Please don't waste either of our time with low ball offers. Thanks for looking!
Call Joe - 3 zero three three four 5 five 8 nine 3
IdaSHO
IDACAMPER
'bout the only thing that would make it better IMO would be a manual trans.
Other than that is looks like a fantastic rig :ylsmoke:
inter17
I've got one for sale too. I haven't listed it yet, but it's a lot cheaper!!
I'll have pics soon if there is any interest.
gp01
