Best Bed Liner??
Flashole
My m416 tub is coming back from the sand blaster in a few days, so it's time to place an order for some bedliner. What's the best product to use? Monstaliner? Raptor Liner? Herculiner? Something other?
Which product do you guys recommend and how much should I order? Will be doing the underneath and inside of the tub.
Also, does this stuff get applied directly to the bare metal, or should it be primed first? I'm assuming that it needs some sort of primer first.
TheThom
I've used both Grizzly Grip and Monstaliner. I have to go with Monstaliner as the better product. If you call their service line, they are VERY helpful! I was applying to new aluminum and they walked me through the prep, priming and application process.
G.Nenzel
I have used durabak and highly recommend it.
Word of warning, mask off everything and I mean everything you don't want to paint. I have over spray on my garage floor that still looks like the day I applied it over 4 years ago. If you don't remove it right away, it is there forever.
Flashole
That's a good thing, except of course for your garage floor. Hadn't heard of Durabak. I'll look it up.
The Raptor Liner looks intriguing. Anybody have experience with that stuff?
foo.c
Line-X is the best, IMO.
I used Duplicolor Bed Armor on my m416 and I'm pleased for the most part. It took 3 weeks to fully dry though due to a lack of sunlight and warmth, so factor that in. Also, I would ditch their roller if I did it again and figure out a better way.
