1994 Montero SR with rebuilt engine at 150K
newworld2004
Hi, all
came cross 94 SR with 150 K on it, according to saler he had to rebuild engine , because timing belt broke, he is asking 2500 for it, has not seen it yet, I am no mechanic so I am just afraid of other expenses beside engine work. He is saying it is in good mechanical condition.what do you all think. ?
thx
off-roader
Ask to have it tested by a mechanic to look for all items of concern. May cost you to do that but if he's willing it may be a good ride.
Toasty
I'd almost guarantee it was rebuilt as cheaply as possible to be resold before something bad goes in that motor. It's quite common with those motors and i've seen it personally multiple times. Ask for receipts for the parts installed and receipt for labor, probably non existent or rebuilt with junkyard parts. Tightened to spec with a 1/2"DR ratchet and a 20" pipe for more leverage. :Wow1:
SoCalMonty
Most sellers don't know what junkyards are...that's more of a hobbyist resource. And its nothing typical with these engines at all - it's any interference engine where the timing belt isn't replaced at the proper interval (or fails early). He could just as easily had a mechanic fix it. Ask for the receipts, as mentioned...that will give you your answer. :)
SoCalMonty
Thx , all for reply, according to seller, his friend did the work, so there is no actual mechanics receipts.
Do a compression and leakdown test, and pull off the cover to check the condition of the timing belt. How it was repaired or who did the work is irrelevant; if the engine is healthy, it's healthy. That's all that matters really. Good luck!
iStan814
