Hi everyone,
I finally felt I had enough time (and money) and decided to take the plunge and convert over from the 6.2 to the 5.9 and, at the same time, go from auto to stick. So here are some pictures in case the internet needs more pictures of chevys with cummins' in them.
I wanted to show these pictures because this shows clearance with a Dodge Dana 60, off of a 93 Dodge, and the autoworld cross member. One thing I'm going to do is change the breather port to a 90 degree to provide more clearance for flexing. Also, as another note, what you're looking at is really a 5-inch lift. The tuffcountry springs are the HD 3500lb 4-inch springs plus the additional inch from the spring perches on the Dodge being 2 inch as opposed to GM's 1 inch. I really thought with the cummins there would be more sag, but as off now, its sitting a little higher than the 6.2. Although, I still have a transmission and a transfer case to install.
Another thing I have pictured below is my two rear front spring hangers. One of them isn't very happy and is mostly bent (passenger side). The Dodge 60's perches are .5 wider than GM's, but that's .25 inch difference for each mount to take up. Not that much, however, one bushing must be worse off than the other and so it failed. So those are getting replaced this week with heavier-duty ones from offroaddesign. Pictures later.
Also, on the list of things-I-still-need-to-do is extend the dodge shock perches to accommodate dual shocks. There are a few other things that need to be done to the front axle, but Ill post those when I get to them.
Driver side - how it should look:
Passenger side - how it shouldn't:
