Gen 2.5 - Misreading Voltage Meter
nwoods
I'm in the Bay Area, live about 10 miles North of the Golden Gate bridge.
yeah, probably not quite close enough to have a wrenching party :)
Maybe OffRoader can get you connected with some folks up there.
CarlosC
nwoods,
Any luck with the in-dash voltage meter? I am having a similar problem with my 2.5. I recently replaced the alternator after a slow valve cover leak soiled the old one. The alternator is up and running just fine. Only problem is now my battery light, brake light, and A/T light are on all the time. Like you, my in-dash voltage meter has never been above 12 volts (with the old and new alternators), even though the new alternator is reading 14.45. I am thinking I might try and replace both the oil pressure guage as the manual suggests as well as the voltage meter. Have you conducted the resistance tests that are suggested on page 54-25?
Carlos
nwoods
Carlos, thanks for the on topic comments. No, I haven't made any progress yet. I plan on tinkering around with this on Saturday. I'll post up what I find
off-roader
Yeah, it's a mystery to me too. The alternator my mechanic used came directly from a Mitsubishi dealer as well. It's easily been a year now; likely closer to 1.5 years since I had it replaced as I think it was very early 2012.
Will have to get my hands on a good volt meter and do some testing at the battery and the car-meter if I'm able with the engine off and then running.
With the alternator that old its unlikely to have died on its own assuming its a rebuilt one but not if it was a new OEM unit, unless you have other issues like an oil leak, leaking oil onto it. That will kill it pretty quickly.
We're kinda distributed around the SF Bay Area. I'm probably the farthest in the Tracy area. Grasscat is in Livermore. Cap510 is in Fremont. There are others as well but they dont frequent the forum.
GFO
As far as I know, it was the original alternator.
Thanks for the infor. This morning, it was reading 14 volts( a notch beyond the 12) and it happened to be mid 60's this morning. It does seem like the meter reads (or the alt puts out) according to the ambient temperature.
nwoods
Very peculiar but welcome behavior today. I visited local Mitsubishi dealer and got replacement bulbs, and while there I got a spare Ignition key made (only $17 !). Testing the new spare, I was able to start the truck WITHOUT having to push the alarm override! This is the first time my truck started normally since the first full day if ownership when I disconnected the battery to clean the terminals.
Pleased, I started to drive away when I noted my Voltage gauge was reading 14+ volts! Did it heal itself? Are these keys (98 gen 2.5) chipped with an RFID chip that might have cleared the alarm circuit finally?
CarlosC
Nathan,
Congrats on the fix. FYI, I was able to correct my low voltage meter readings by removing the multi-meter cluster and disconnecting the harness. After I plugged it back in, the voltage meter began reading above 12v. I don't know if you are still getting consistently accurate readings, but if not, you might want to try this. It was a quick 10 minute fix.
Mudrunner
Lol it has been my experience that sometimes all you need to do is remove and replace the connectors. Just works the so called "rust" off of things.
nwoods
Long saga of silly light bulbs. I finally got the right bulbs, and, um, replacement sockets for the ones I lost somehow.... and replaced all the burnt out bulbs in the dash. Yeah! Then I turned my attention to the voltmeter. I'm seeing about 12.5v at the battery with everything off, and about 14.2v with the truck running. The gauge is beginning to read more consistently (it has been in the low 90's at my house lately), but its consistently showing about 11v. I'm just going to disregard it in the future. If it shows zero, and the car won't start, I'll start to trust it :)
Now after unplugging, cleaning, and reconnecting the gauge pack harness, the digital compass doesn't work. I've manually reset it several times today, and it just perpetually wonders where South is. It used to work, now it doesn't. Fortunately, I have an excellent sense of direction and a pretty good memory for trails. I was amazed at how stout and overbuilt that gauge pack assembly was. I've seen flimsier winch trays (yeah, Smittybuilt, I'm talking about you).
Still waiting for a business deal to go through to fund my lift, tires, and maintainence overhaul. My neighbor saw me working on the truck today and came over to chat. Turns out he was a service manager for Southcoast Mitsubishi for a few years. Loves the truck and has nothing but praise for them. BUT, he strongly advised doing the timing belt and Replacing the main crank bolt along with the water pump and idler...something (gears?). Says he saw a number of Montero's flatbedded into his shop with all the belts hanging out the bottom of the car after a 3rd party timing belt job. I guess the crank bolt doesn't like being retorqued? Anyway, I thought I'd pass it on as it was news to me.
off-roader
yup, timing belt, crank bolt water pump, tensioner, and idler pulleys should be hanged although in my experience, the idlers don't need to be changed every timing belt change, but they're cheap parts so you may as well.
CarlosC
Nathan,
As for the compass. The service manual recommends pressing the reset/calibration button then driving the vehicle in a slow 360 either direction. That will re-calibrate the compass. Check out page 54-15 if you have the manual.
nwoods
Nathan,
ah see that's my problem. I never drive in circles :)
Thanks for the heads up. I do have the service manuals, but didn't think to look there for this specific bit of info yet.
Evo666
I have this problem too. I was thinking if I can replace the gauge with something else. Maybe aftermarket volt meter.
Update. I somehow fixed the misreading gauge with fresh new battery and alternator. It was reading well under 12v. Possible dead cell in the battery caused this.
oskarf150
