2016 Wrangler: Reading the tea leaves
Dan Grec
I'm a little surprised Jeep isn't looking to make more of the body out of plastic. Realistically they could make the entire tub out of plastic as long as the frame and rollbars maintained their strength.
Do you think it would be rigid enough?
i.e. I think it would be very bad for handling if it flexed during cornering, etc.
Are any other manufacturers making significant parts of a car from plastic?
-Dan
conifers4
Suburban nomad
Who cares if soccer moms drive them and don't wheel. THEY are the ones that keep the Wrangler alive believe it or not. I don't care who buys them as long as someone DOES. Simple economics, if they don't sell, Jeep will no longer produce them. The small portion of "wheelers" will not keep the Wrangler alive. If they want to spend their money on a Jeep to bus the kids around so be it.
Grasslakeron
Actually you should care. Case in point, the ford explorer. Started life as an suv. Soccer moms loved them. In 2002, ford changed them to make them more to that demographic.... now when the demographic wanted cuv's so went the explorer. The wranglers demographic is currently the soccer mom. Unless jeep stands their ground you will have the wrangler cuv.
Ron
Justincredible
-Dan
Being a body on frame, definitely.The frame will keep it rigid while the tub could shave weight (this would also lower the center of gravity).
A lot of manufacturers are using plastic bumpers, even the Corvette has plastic body panels, but being a unibody chasis parts of the body are structural and must be metal or carbon fiber.
conifers4
Suburban nomad
Maybe but the Ford Explorer was never marketed as (rightfully so) an offroad capable machine. A lot of vehicles come with 4 wheel drive, doesn't mean they can truly "off road".
toylandcruiser
Ditto.
Have had air bags burst on two other vehicles. A good coil spring is darn near failproof, but when an air bag bursts, you are SOL.
R
That's funny. Then explain why hemtts have airbags and we trash them offroad while carrying 30000 or more pounds. Airbags are not weak by any means.
ΜΟΛΩΝ ΛΑΒΕ
Grasslakeron
Yet what does offroad to a soccer mom? Remember whos buying them in bulk? So when the ball washer becomes an option with its IFS, unibody, latte maker and flower holder then dont blame me.
Ron
the grouch
Don't they sell replacement tubs for CJ's made out of fiberglass? I don't see rigidity being an issue either. Meeting crash safety standards could be. And the insurance companies won't like it, I think. Replace parts instead of fixing them?
EMrider
ΜΟΛΩΝ ΛΑΒΕ
No mystery there. HEMTTS must be equipped with very robust airbags. The vehicles I've experienced obviously were not.
R
jeepdreamer
R
First gen HEMTTS didn't use airbags. A4s do and they ride like a caddy in comparison. I think if it were done well it would be a great design...for a Cherokee. But with visions of Range Rover ab issues in mind I would say nay on them from the factory in a JK. Just me. :)
toylandcruiser
Land rover can screw up anything though
ΜΟΛΩΝ ΛΑΒΕ
Longtallsally
I dunno, I guess it doesn't really matter the more I think about it. There are literally over a million JKs on the road. That said, parts will be around for a long time. Get one used and make it what you want since the manufacturer really could care less what a minority of the customer base wants.
oskarf150
