Small Solar Panel To Charge Flashlight
D45
Long time lurker, first time poster...........
I have a 3 hole, 12V accessories strip in the bed of my truck
However, I do not like to keep things plugged in all the time, so the truck's batteries do not drain
I was thinking about mounting a small solar panel on top of the cap, and keeping it plugged in , directly to my rechargeable Maglite
1.5 Watt Solar Battery Charger
Good or bad idea?
The Maglite uses a 6V battery.......even if I find a solar panel that is 1-2 watt capacity, it might take longer to charge, but it will be charged all the time and won't be an additional pull or load
A few panels I am looking at:
Weatherproof 1 5Watt 12volt Solar Panel 12V Battery Charger Maintainer w Plugs | eBay
1 5 Watt 12 Volt Solar Panel Weatherproof Battery Charger Maintainer w Clamps | eBay
I am only looking to charge a flashlight, or provide enough power to have it on a slow charge
It does not need to charge the flashlight in 1-2 hours.........just in between uses, which might be 2-5 days
I was thinking a 5W panel should be more than enough, but was just guessing
Lumpy70
Just keep in mind that a 5W solar panel will only deliver 5W under lab conditions with perfect light. When planning for solar you need a panel with 2x the wattage as what your loads are.
My 60W solar panels on my trailer deliver 20W-40W during the day when in direct sunlight, never actually approaching 60W delivered.
Also, solar panels degrade efficiency at 1-2% per year, so a 10 yr old panel could be as much as 20% less efficient.
Just food for thought.
D45
Thanks for the info......I would not be using the light daily, just 1-2 times a week
I was hoping that the weekly charge would be enough to maintain the 6V battery with a 5W panel...............but maybe I should look for a 10W panel, since it will soley be used for the Maglite
D45
Is anything else needed or required...... or can the solar panel be wired directly into the charger?
