Cyclone pre-filter install on V6 '05 4Runner
teotwaki
Excelsior!
Wahooo! A package on the porch today!
Brand shiny new cyclone pre-filter from 2008 FJ Cruiser
Spinner
Out with the old using 12mm on the bolts and 10mm on the clamp
Side by side
"Scoop" on the old inlet fixture
Water drain holes on the old fixture
Big hole in there
nice fit into fenderwell
Shiny new Pre-filter
A big THANK YOU to Robert and Scott at Findlay Toyota of Las Vegas!!
teotwaki
Excelsior!
TACODOC said:
Nice, first one of those I've seen.
What is the difference between that and your OEM piece? Cost?
List price is $132 IIRC......
I got it to my door here in SoCal for $100
Differences are the lack of the scoop, the spinner blades that knock the dirt down into the squeeze blub, a more straight-thru tube and no open water drain holes.
teotwaki
Excelsior!
When I was getting ready to add a scoop to the inlet I pulled the dust drain-nipple-thingy and discovered just how much street dust the prefilter had grabbed in 3 or 4 days of use
The FJ Cruiser inlet scoop is not going in. It is a huge headache to pull the inner fenderwell skirt and halfway thru I gave up and put it back.
I bought a PVC "street elbow" with a flange on one end which I shortened up and I modified the inlet area too
On the pre-filter I cut its rubber inlet flange back about an inch leaving a little ridge to ensure a tight fit. I used a silicone type sealent to glue it together
I added a new strip of rubber sponge weather stripping and plugged the whole thing back into the fenderwell.
The inlet is angled slightly upward which gives me roughly 40-41 inches above the ground for water fording
teotwaki
Excelsior!
Yesterday I spent 4+ hours on the Cleghorn Trail as tailgunner for a group of 12 trucks. The trail was dry and very dusty. Here is what the prefilter kept out of my paper filter
The paper has 1/4" square grid lines.
4RunAmok
Hey Jim!
That looks like a pretty cool add-on! Very functional! I'd call that thing a guard moreso than a scoop, as it shields from head on dirt. Was glad to see you made your own, which also looks quite functional on its own besides saving you from removing the fender.
I didn't realize you were so close. I'm also local to Cleghorn. We did Cleghorn a few weeks back, great trail, took it all the way to the 138.
Ever checked out www.explorehistoricalif.com? They run tours in the Mojave and Owens Valley areas. Great history and offroad trails! They're local, and I've been on a few trails with them.
We should hook up. Yesterday we went out with a guy from another forum, and he showed us some GREAT trails in the Big Bear area. Incredible run!
corax
Back from the dead . . . . does anyone know / remember what the outside diameter is on this? I'd like to run a tube from my airbox back into the cowl similar to this (not into the passenger compartment, it's already loud enough) and would like to size the pipe now so I can add one of these in later without having to change tube sizes
Toyota Part Number : 17730-31030, right?
teotwaki
Excelsior!
take a look at the pictures in the first few posts and tell me where you want the tube measured. The part number on the outside should be correct.
corax
I need the inside diameter of the rubber intake tube on the right side of the 4th pic and the outside diameter of the part that the street elbow fits over - basically, want to put one inline inside the fender (fiberglass fenders/no inner liner) so I just need to know what size PVC to run. I think I see a "3" on the street elbow, but can't tell if that's the size or not. Thanks
teotwaki
Excelsior!
I'll try to get you the info. The street elbow is glued on so I can't measure it but let me see if I have info elsewhere as well as enlarge the original photos.
teotwaki
Excelsior!
Long term report, how has the Cyclone been working for you?
The thing continues to surprise me with how much grit it poulls off of the street. Trail runs in the hills and the deserts still continue to result in this:
That is all grit that would have clogged the air filter or even made it through so I think it is a great investment.
ebg18t
Is the part # different for the 4runner? Seems like a good time to replace my current one with a new/better/cleaner one.
V45W_Proto2.5
