I'm not knocking what's on 4Wire, I just can't extract any of it.
Exactly
There are 3 ways to find info there... the FAQ thread at the top, the forum search, or the built in google search. I dont usually have issues finding things. How do you do your info searches?Exactly
Or, we can do like we are doing now and complain about it, not use it, and carry on. Its just a poorly executed forum. Who gives a flying fornication?
Mike,Click on a post with many replies and where does it take you, to the first.
One thing 4x4wire has over this forum is there is 70% less whining going on over there.
going back to suspension.
Nathan, tell me more about these Peddar's springs. How did you like them on your LR3? Any idea how much they cost for monteros?
Just FYI, they have two versions, the regular sliders and their supersliders. The ones in the pics are supersliders which have the outside round tube attached to the main square tube. The standard ones only have the square tube which doesn't offer the nicer look or the additional protection.
As for powder coating, they just come that way and the coating lasts several years (from others that have had them), of course, requiring touch up on the bottom where they take the most beating. I'll probably go with herculiner or line-x or even epoxy paint when mine require repainting.
:luxhello::luxhello::luxhello:This forum needs a LIKE button LOL.:luxhello::luxhello::luxhello:One thing 4x4wire has over this forum is there is 70% less whining going on over there.
I believe the Mitsu springs are progressive rate (not constant rate) but I suspect Scott's failure is simply a combination of their age and the vehicle's weight when full of gear. Also in my searches, I've found pretty much all the other aftermarket springs available for Montero's have been constant rate springs. I wonder how well a set of airbags will work when coupled with a pair of new rear coils and heavier duty front torsion bars.To answer this question, you need to know a bit about my old LR3. It was a very rare model here in the States, as it did not have the standard air suspension but came with coils instead. In reality, while more durable, it did not provide the normal LR3's advantages in articulation and selectable ride height, and, it was a constant spring rate so it suffered from load weight issues similar to what Scott has suffered in his Monty...
I'll also try & ring them directly in Australia. My client base are all down under so it's no biggie for me to call there to find out.I have sent an email to PeddarsUSA to find out about pricing and availability of the Montero kit, and will post what I learn here.
