bftank
I'm well aware of that. I'm also very familiar with those axles. Apparently you're not. Regardless of what kind of wheel is on it, that IS a DRW axle.
in your previoius post you gave no indication, other than there was a dually wheel on it, as to why you thought it was a dually. forgive my assumption, that you were implying it was a dually axle based on the dually wheel alone. please enlighten me as to how you know it is a dually axle based on the pics provided. i am always open to new ways to identify them.
not sure where you get that i am unfamiliar with dana 70's. i have had several. i was merely indicating that the best way to find out what you have is to measure it and pull the axle shafts to determine which 70 he had, because they were used in many different configurations. if he can find the BOM number that would be even better.
it could very well be a dana 70 dually, never said that it wasn't. there is no probably about it being a 70 if the diff is stamped in a corner, from what the op said. no offense was intended.
maybe not being curmudgeonly is something to work on :friday:
