Help. Skamper heater not firing up. Fan OK.
Stereo
I have a 1980's-something Skamper. Last fall, the heater worked just fine. This year, the fan comes on but the pilot doesn't flame on. I don't smell any build-up of propane. Yes, the propane is on at the tank and at the main heater shutoff. I did clean up the contacts to the electrode assembly. I can live without the heater but it sure is sweet to heat up the interior a bit before crawling out from under the down.
Here's what the heater looks like along with the wiring diagram. I'm hoping whatever part might need replacing - if it's something broken - will still be available.
kb7our
Might sound dumb, but verify polarity at the battery connections. I had a 90s Coleman Taos and the battery positive and negative were swapped which still allowed a brand new heater fan to run but not ignite until I swapped the wires, white negative/black positive, in this case.
Stereo
Check you r battery, If it is too low it won't fire. The fan may still work, but the igniter won't.
It appears you're on to it unless it just coincidentally started working again. I plugged into shore power and it started right up. I connected my battery to my Schumacher charger and it read 60%. I can't believe that wouldn't be enough!? Is that other people's experience? Unfortunately, I didn't try started under battery power again before charging it over 90%; it worked.
The only other thing I did between tries was to turn off the master shutoff overnight and then back on this evening, and drive it about five miles over paved roads. Perhaps the spider/hornet/other crawlie found another spot to hang out. :) (Thanks for the tip, azken.)
kb7our, I don't mind suggestions that state the obvious. I've done stupid stuff before, so I appreciate the double-checks.
Anyway, it's working... for now.
Joseph McCormack
