Actual height of an Xterra Pro-4X
Imager993
Pixel Monkey
Hey all! I'm looking to get a new Xterra Pro-4X in the next few months here, and will hopefully start to be active here on this board once I get it.
I've been looking at the published dimensions of the Pro-4X to make sure that it will be able to fit in my smaller garage space and have noticed a discrepancy. When I took a look at the Xterras at a dealership, I noticed that the Pro-4X was sitting noticeably higher than the S or X. When I look at the published dimensions though (on both nissanusa.com and edmunds.com), they list all of the models at 74.9 inches tall. They don't show the Pro-4x as being any taller.
Does anybody know what the actual height is of the Pro-4x? I'd like to make sure it will fit through the 80" tall opening to my garage. I might just have to head across town to a dealer and measure, or see if they'll let me bring one all the way home, but I thought I'd check here first.
Thanks!
Aaron
ryandavenport
Thanks!
Aaron
80 inches shouldn't be an issue at all. If anything the Pro-4X should only be a half inch higher than the standard 4wd models because of the inch larger tires. The 2wds set lower in the front, but the rear of the truck is the same height.
