All new SmugMug coming 7/30/2013
photoman
Should be under Gallery Settings > Security & Privacy.
Yes you are correct. It SHOULD be. However the options are: Inherited (unlisted), Unlisted, & Private. Not an option to turn my unlisted folders/galleries to Listed.
I have an email in to them and a thread on Dgrin. Hopefully they will make a quick fix of this.
Lost Canadian
Aaron if you unrestrict the "folder" in which your galleries reside and then simply unlist those galleries you don't want to show you'll be good. The inherited option pulls security settings from the folder settings . If the folder is locked down an you select inherited for a gallery then it inherits those properties.
Lost Canadian
Mine's done and I love it. Took me about an hour, maybe two, of total time just playing around. I'm also working on a couple different layouts to change it up from time to time. I love being able to create and save different looks. I've also consolidated and streamlined my galleries into three, keeping it neat, easy, and clean. My folders are open but nothing links to them, they're only buckets for galleries anyway and those, with the exception of the ones I want to show, are locked down. I simply redirected my header links to go straight to the galleries I have unrestricted. Can't believe how good of job they did, it's amazingly easy to create and recreate stunning galleries now. And for the pro's, selling and setting prices is even easier than before. I couldn't be happier. Bravo smugmug!
photoman
Tried that. There is not an option to make the folder public
This is what it will look like (eventually)
photoman
So I had to recreate all of the galleries but now it is at least working like I wanted.
http://aaronnewman.smugmug.com/
Still have to populate the galleries with some images and reorganize/ hide a bunch of images. I will also look to customize the sections I have for family and my son's photography.
Tucson T4R
After looking at other folks' sites and viewing on my iPad and phone I decided a few changes needed to be made. I dumped the black background, turned off the covering effect and stretched it to full width.
Works much better now on all devices. :victory:
http://bgarland.smugmug.com
nwoods
Wow Brad, though I've seen most of the photos you posted on your smugmug site before, seeing them all at once was a very impressive experience. You've got a great body of work and some really powerful images.
However, having 3 or 400 hundred images on the home page is a big overwelming for a mobile user. I had to wait until I got to a computer to see it. Not sure if there is a way for you to pick your top 10 and limit the homepage to that or not, but you might consider it.
Tucson T4R
However, having 3 or 400 hundred images on the home page is a big overwhelming for a mobile user. I had to wait until I got to a computer to see it. Not sure if there is a way for you to pick your top 10 and limit the homepage to that or not, but you might consider it.
I say, screw those mobile users, let them get real systems with 27 inch monitors. :elkgrin:
I like the collage format on a large screen better than a slide show like I had on my old site. I get your point though, on an iPhone it's a ridiculously long stream of 96 photos.
I should at least cut the number in half. :sombrero:
photoman
Brad- you are fine. The next version of smartphone will be plenty large enough to display your pictures.
4xCoffee
