Some SoCal wheeling this past weekend...
Inyo_man
Don't piss down my back and tell me it's raining.
Wyman Cyn is closeed due to storm damage. We came back down the same way.
I just returned from a trip to the White Mt. area.
Wyman Cyn. is officially closed as stated above due to a storm about two weeks ago- Edison has not been in yet to repair the damage. The trail is passable. A couple of narrow sections and one two foot drainage rut (that you can get around).
Offroader:
Did you do any other trails in the area?
SoCalMonty
Do you have your full fan shroud installed?
It seems like it's normal (or at least common) for them to get above the normal range when climbing in warm weather...yours would be the 5th Montero out of 5 that tends to do this, including mine, but I don't have a fan shroud so that's why I was curious. In other vehicles I've owned, no shroud = overheating. It makes a significant difference in the amount of air the fan can pull through the radiator. The vented hood made a noticeable difference and seemed to offset the missing shroud.
Anyhow, do you have plans to upgrade? My solution is a larger electric fan...just gotta get off my butt and install it!
iStan814
